Eric Capozzi
68 Electro 12 project
Eric Capozzi
I found this Wheel Horse Electro 12 for sale. It is definitely going to be a long hard project. I am needing a little help on the electric clutch/pto. It is completely frozen....any ideas???
bowtiebutler956
I'd start by soaking it down with some PB blaster. Looks like a great project! :WRS:
Matt :flags-texas:
Eric Capozzi
yeah I've been using some Ion activated penetrating oil, liquid torch and PB... Tried using the 5/8" x 11 bolt they tell you to use and so far no luck. This is my first restoration of anything. The metal is pitted real bad so I took the hood off and gave to my buddy to work on, hes a body guy so hopefully it will come out good.
Matt :flags-texas:
Thank you. Proud to have just bought my first Wheel Horse.
bowtiebutler956
You definitely got a good one to start out with. Mine looked about like that before I restored it, right down to the bird droppings all over it. :ychain: I don't have any experience with those electric clutches, but I would continue to soak it, and maybe some gentle massaging with a hammer. Good Luck with your Horse, and keep us posted on your progress. :thumbs:
Matt :flags-texas:
Eric Capozzi
I will definitely post more pics
Jake Kuhn
:WRS: Looking forward to seeing progress on it! Jake
Eric Capozzi
Thank you, looking forward to doing this project. I'm considering a complete rebuild of the k301 that's on it. Original owner used it to mow up until 2010, a guy bought it to restore and never touched it, just left it outside. No deck, no plow or anything just the tractor. I am wondering what the original size deck came on it. I've got the original manual and sales receipt. The guy couldn't find it but has now found it and is mailing it all to me.
jay in nc
for a deck there are i think 3 choices, a 48 in side discharge & 42 in rear & side discharge. all three are reasonablly priced. Jay
smoreau
Also a 36" RD and SD decks were the most popular for that model.
Eric Capozzi
There's a guy here local that has a 41" deck....most likely a 42" deck he wants $150 for it. It is in fairly decent shape.
Lars
can whlvr
if the deck is in fair shape thats a fair price
TT
:WRS:
That tractor could have had a 36" two-blade (rear discharge), 42" side discharge, or 48" side discharge deck when sold new. The rest of those mentioned above weren't invented yet.
You may end up needing to press the crankshaft out of the clutch & drive pulley if it's stuck that bad.
Eric Capozzi
well I got the clutch freed up, hopefully its salvageable. Only problem is the clutch still wont come off....I guess time will tell
jusjeepn
My $50 69 Electro started like this,
After fluids changed, fuel pump, carb rebuild, new fuel line and a little wiring,
After a little paint,
And a few more for good measure,
It sat outside it's entire life before I got it. For 3 years before I bought it, it wasn't even started. Now it's one of my main workers. It does all the ground engaging work so it's getting quite the workout here lately getting the garden ready!
Eric Capozzi
Very nice
farmerall
Looks like it will be a fun project and it looks liek a complete tracotr so you won't need to find alot of parts.
I have a 69 Electro 12. I think it has a 42 inch deck on it but I never measured so I can't be sure. Also I think that they came with hubcaps originally too and If you want to get a pair of them they can be pretty expensive.
Eric Capozzi
So just an update on the Electro. I finally got everything freed up. All the handles work great. Looking to buy a throttle and choke set because the old ones are trashed. Not sure if the hydro works yet but it does still have an original Wheel Horse filter on the Trans. I thought that was awesome. But it's gonna have to be changed I'm sure. The governor gear shaft is bent a little, not sure if it's supposed to be like that or not. Computer crashed but I will post more pics soon.
  • Similar Content
    • D_Mac
      By D_Mac
      Well...... what's too many horses ? Is to many when you have no more room in the garage so you have to start leaving them outside ? You can say you are "tractor heavy " but are you really ? Right @WHX??. I picked this up today. I'm not really a parts buying guy, unless I need them, but I saw this listed and you know. Love at first sight. Appears i just bought a 1969 Charger 10. Or parts of one. PO removed the original tecumseh engine and was going to install this 10hp Kohler. Well as you can see he didnt get far. Engine is on frame not properly secured and nothing else is hooked up. Nothing. Wires hanging all over. Parts off of it. Im not sure if i have everything. I also am unfamiliar with these " newer engines" that dont have the old starter generator.  Not sure what works and what dosnt. Just got it home. If you kind fellas can take a look at what i photographed and tell me whats missing or what i will need to attempt to get this thing running again or if I just should rob some parts from it. Wiring it will be very difficult for me. I have said 100Xs I'm a horrible mechanic and even worse electrician. What ever I decide to do with it your opinions will be appreciated. Thanks
    • 12 hp Kohler
      By 12 hp Kohler
      Been looking at a lot or Raiders and Chargers lately and was wondering if they all have LSD? I know most of them did but I was wondering if some of the later models might have had the Uni drives instead ?
      Thanks, Robbie.
    • RJ Hamner
      By RJ Hamner
      I am wondering if there was ever a Service Manual for this particular tractor.
      So far all I have found are Owners Manuals (one came with the tractor)
      Since this is my first attempt at a HW with a Hydro I am probably going to need all the help I can get
      Any help will be appreciated
      Bob
    • Nate89
      By Nate89
      Look to see if someone can help me with on identifying my wheel horse on what year it is wheel horse charger 12 modle 1 0401 7
    • Conner Anderson
      By Conner Anderson
      I own a Charger 9, it is a 68 and I am wondering what I should ask for it.
      I personally want to trade it, just cannot find anything worth my efforts.
      I found a younger gentleman in his 20's, he's over 650 miles away from me and he has himself a raider 12, I want it just he wants two tractors for it.
      I personally feel my Charger is worth more than 250, as it is one of a kind.
      Please, let me know.
