Shuboxlover 478 #1 Posted April 5, 2012 I got it running, runs o.k. but makes a big puff of smoke when I rev it up. The throttle shaft is wore (are those hard to fix?). It does move, I haven't actually driven it, but it moved a couple feet back and forth with no problem. I think I may rebuild it this fall/winter. Share this post Link to post Share on other sites
Jake Kuhn 1,554 #2 Posted April 6, 2012 :text-worthless: 1 Share this post Link to post Share on other sites
AMC RULES 37,125 #3 Posted April 6, 2012 :thanks: :ROTF: Share this post Link to post Share on other sites
bowtiebutler956 650 #4 Posted April 6, 2012 I tend to agree with the peanut gallery. Matt :flags-texas: Share this post Link to post Share on other sites
Jim_M 178 #5 Posted April 6, 2012 Normally the throttle shaft is loose because the carb body is worn. You can install bushings in the carb body and a new throttle shaft it's not difficult but you need patience and the right tools. A drill press makes the job go a lot easier. Share this post Link to post Share on other sites
