Nick Vaughn
hi i have a 76 b-111 old school well after 30+ yrs the tires need changed the current size is 22x7.5-12 can i swap them with a 23x8.5-12 without alot of hassle thank u guys
Kelly
Yes a straight fit, most models come with the 23x8.5x12 tires, the rims you have are the same as the other tractors.
and :WRS:
AMC RULES
:WRS:
Sparky
I'm surprised that a B-111 has 12" rear rims. Are you sure thats the correct size?
I thought they were 10" or 8" rears.
:WRS:
Mike.............
bowtiebutler956
:WRS: If you do have 12" rims then you can buy a set of 23x8.50-12 ag bar tires from Tucker Tire on :techie-ebay: For $103 a pair. That's what I did. :thumbs:
Matt :flags-texas:
Jake Kuhn
As mike asked too,are you sure that that is the size it has because my b111 has 18x8.50-8? Jake
Nick Vaughn
i ahve to doulbe check the modle i know i had a b-111 may ahve been confused lol cant remeber the other one lol either way the current tire is a 22x7.5-12
Nick Vaughn
and my speeling is horrible lol so bear with me
Sparky
I bet what you have a B-100. I think they came with 22x7.50x12. If thats the case, yes, you can install 23x8.50x12's.
Mike........
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
