dwcphoto
Sundstrand Hydro Wheel Horse 518-H
dwcphoto
Hi Mike,
Thank you for thinking of me. I picked up one yesterday that should be fine. Back story is it came out of a 520 that was crushed in an accident, so has only a few hour on it. I'm sure you all will be hearing more from me as the project progresses! thank you, dwc
Phife
On 3/28/2012 at 9:41 PM, dennist said:
Here is a Sunstrand-Equal axle lengths on both sides.
What is this tube that goes through the tool box? I have a 68 charger 12 that is the same?
953 nut
:WRS:
That tube is for a cable from the lift rock-shaft to the rear sleeve hitch/slot hitch to lift rear attached implants.
Phife
Just now, 953 nut said:
:WRS:
Thank you
JaysHorse
My 518H has the 700. With a little luck I may be scoring an 1100 but there are about 1600hrs on it.
