JamesBe1
Rescue Horse
JamesBe1
Well, after lots and lots of drilling, I finally decided I had drilled enough. The last thing I wanted to do was to drill through into the crankcase by being off center. I think there is still a bit of easyout in there, but it appears to be part of the block now.
I got a tap and die set in the mail this morning and spent the afternoon tapping new threads. Had to take a break to go pick up a sulky from Jeff in Ct. That's one of my next projects.
After tapping it out as deep as I could. At a certain point, I noticed it going off center. I figured that was because of the remnants of the easyout (not so easy to get them out!). I called it quits after I was pretty sure that I had threads into the block. After taking the tap out, I noticed that it's threads were dulled pretty badly from trying to cut the hardened steel of the easyout. I drilled out the threads in the cover plate after that.
I couldn't find the right length bolt at any of the local places. The correct length is 1 3/4". I could only find either 1 1/2" or 2". I tried the 1 1/2", and it was a little too long, so I had to cut it down. Apparently, I could have drilled even further, but the cobalt drill bits were dulled at this point from hitting the easyout.
Started to reassemble, and found that the bolt was now too short as I didn't take into account the thickness of the lock washer and the engine tin. I know, I know. You're all thinking that it doesn't give me a lot of thread to hold it in place with if that much distance made the difference. You're right, but at this point, if it holds, I'm not going to cry about it.
So I got the 2" bolt, and cut it down a bit. Apparently, I cut it too little, so I cut it again and it finally fit (ponder that for a while!)
I am now happy to say that it is all back together again. Some the worse for wear (me too), but at least now I can keep moving forward.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
    • Nathan W
      By Nathan W
      Does this look factory for 1976
