dw753 208 #1 Posted March 27, 2012 Will an air cleaner cover from a 12hp kohler fit a 8hp kohler? Need an 8hp air cleaner cover and found a 12hp but don't want to have it shipped here if it won't fit Share this post Link to post Share on other sites
WH854 44 #2 Posted March 27, 2012 Will an air cleaner cover from a 12hp kohler fit a 8hp kohler? Need an 8hp air cleaner cover and found a 12hp but don't want to have it shipped here if it won't fit NO! Try Kelly(vender) on RS Chas Share this post Link to post Share on other sites
Hodge71 665 #3 Posted March 27, 2012 Really Chas? I might be showing my incomplete knowledge base but I could have sworn all air cleaner covers from Kohler's K series engines from 8-20 hp were interchangeable. My K482 had one from a 10 on it and it fit just fine. The air cleaner stuck out of the bottom a bit because of the taller filter, but it still was the right circumference and ran just fine until I got the proper one for the restoration of my 18 auto. I'm not saying your wrong, just wondering which ones interchange. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #4 Posted March 27, 2012 Chas is correct..... The K-90 thru K-181 engines have a smaller diameter air cleaner. The K-181 also (normally) uses a "deeper" cover due to a taller filter element. Share this post Link to post Share on other sites
Kelly 1,030 #5 Posted March 27, 2012 Yes they take the small air cleaner, if you need the deep one I should have a few, I don't have any narrow ones to sell, but the deep one can be cut down, but as TT said most K181's use the deep one. Share this post Link to post Share on other sites
Hodge71 665 #6 Posted March 27, 2012 Thanks for straightening my ignorance TT and Kelly. I now know the rest of the story.... Share this post Link to post Share on other sites
