jones and son
Antique trencher - Any info???
jones and son
I picked up this old trencher at auction the other day. I was wondering if anybody's ever seen one of these or might know anything about it... Who made it? What year? It has a Wisconsin motor on it.
Any info or helpful suggestions would be greatly appreciated.
Thanks!!
post-2708-0-54192900-1332289775_thumb.jp
Jake Kuhn
Never seen one of those before,Very cool looking! JAKE
SousaKerry
maybe an early ditch witch????
AMC RULES
Who made it?
COMMANDO1
MAD MAX............
jones and son
who made it , is what i wanna know, there is a metal tag on the side with only 1-56666 legible.
KC9KAS
Are you planning on making it operational?
jones and son
well yeah, i got the motor running, ordered a bearing for it today and ordered a sproket from the local
deere dealer, i did have it actually running but the sprocket that drives the trencher only has 2 teeth left (out of 8) so it didnt run smoothly and a bearing was smoking hot after 30 seconds run time. i need to get a flat chain to run the wheel drive part of it,will try to get a pic 2moro of the wheel drive set up on it , its pretty interesting how it drives the wheels. I did find out the trencher chain is a ca550 chain, which is still readily availble,
VinsRJ
Now do you ride this thing or stand along side it? Either way don't trip :angry-nono:
jones and son
its a walk behind
Rollerman
We used to have one of these at work.
As I recall you walked backwards ahead of it with the trencher trailing behind it, one step up from a shovel.
It went to the auction a long time ago...it became outdated with all the new mini track hoes that they have brought in at work.
DoctorHfuhruhurr
I've looked around and haven't been able to find anything similar yet. Are there any numbers on the engine? Sometimes you can find the origin searching on the engine info. It doesn't look home made to me. It's definitely an interesting contraption you got there. It's got a medieval look to it where it could lop off a limb if you're not careful.
jones and son
you do walk backwards ahead of it, one step up from a shovel is fine with me, i got the sprocket and hub in today
with a little maching and welding its back together, might get to test it 2moro!its a wisconsin with a magneto,
the tag reads 3x31/4, i'll get the serial # 2moro.
AMC RULES
I'll bet it's a beast too...would love to see an in action video once it's up and running. :teasing-poke:
SousaKerry
Wisconsin Motors is still in business but they think their parts are made of solid gold.
If you call them they may be able to track down the spec number but records are sketchy at best Wisconsin changed hands many times and records were lost and so on...sound familiar????
Try looking for aftermarket parts for the engine epay is a good source for common parts also try
McDonald Carb & Ignition - Parts and remanufacturing for Carburetors, Magnetos, Distributors, Generators, Starters, Alternators, and more!
http://www.carburetor-parts.com/default.asp
rings and pistons are available from Hastings, Federal Mogul and such but you have to find a dealer that will actually look it up in a book not just look at the computer and says "I never heard of that"
I called a JD dealer the other day for WICO magneto parts and the kid who answered the phone said whats a Magneto? Apparently he never seen a JD built before the 60's
I called their sister dealership and got a hold of someone who actually looked it up in a book and found it. Imagine that.,
jones and son
Got it running... I have a video, but I don't know how to upload it... Can anybody help?
AMC RULES
PM sent. :thumbs:
CRE1992
That's pretty cool, however it is far outdated... I think I could move faster with a shovel and pik =P
Congrats on the find,
Charles
jones and son
it might be outdated, but i stood around talking on the phone while it dug a trench, sounds way better then a shovel to me :)
AMC RULES
Does do really nice work, effortlessly, and it's fun to watch too. :popcorn:
coldone
Even at that speed, way better than a shovel!
Jim_M
You shouldn't plant potatoes quite that deep.
corn53
:banana-rock: That thing is really cool!!! It runs awesome and its fun 2 watch :banana-rock:
  • Similar Content
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
    • Tap53
      By Tap53
      List of various belt Lengths and Widths text
      Chart belt
      Belts sorted by part number pdf
      4 pages 458KB
      Belts sorted by belt section (cross section) pdf
      4 pages 422KB
