COMMANDO1
CRAPSMAN CARB ISSUE
COMMANDO1
Hoping someone can help, my lt100 crasks but wont start when cold, if i hit it with starting fluid it fires right up. If it is warm fires on its own, whats the prob, im burning up my new starter.
Rooster
What engine?
Sounds like a dirty carb, not getting enough fuel.
Are you choking it?
Jim_M
Sounds like the choke isn't working right.
COMMANDO1
16 HORSE.KOHLER...ITS GETTING FUEL THE BOWL FILLS UP AND FLOODS
Rooster
Just because the bowl fills up does not mean the engine is getting fuel, it just means the carb is getting fuel.
I would start with a good carb cleaning.
That is possible, if it is the case then you should be able to hand choke the engine to start it.
If starting fluid helps, that tells you the fuel mixture is too lean.
Jim_M
The float could be bad, improperly adjusted or you could have dirt in the needle and seat. I would take the carb off, give it a good cleaning, inspect the float and adjust the float level.
COMMANDO1
I TORE INTO IT LAST SPRING AND FOUND A REAL SMALL PIECE OF SOMTHING, POSSIBLE DIDNT GET IT ALL. ILL SPRAY IT OUT AGAIN THIS WEEKEND, THANKS TO ALL.
jay in nc
be carefull with that carb, my lt1000 w.kohler 17 broke the throtle shaft at one of the butterfly screws and it sucked that screw into the engine and it scored the heck out of the bore before it bounced out the exahust.wasent 30 days out of waranty. is this the same carb you were looking for a solunide for? pm me i still have the carb.
COMMANDO1
YES IT IS
jay in nc
mailed you the carb today it fit in a padded mailer so it didn't cost much. no charge, jay
COMMANDO1
THANKS EVRYONE, GOT HER RUNNING BETTER CHOKE WAS A LITTLE OFF....MODERATOR CAN CLOSE
