WheelHorse_of_course 101 #1 Posted November 20, 2007 Not long ago I happened to notice that one of the ball joints on the drag link of my 854 was loose. The nut was loose so I tightened it. Today I removed the engine from the Charger (disassembly stake is now done!) and I noticed the same thing on the Charger. So, at the very least this should be a regular point on your checklist of maintenance! Also, if you have steering looseness, check this first! Share this post Link to post Share on other sites
Sparky-(Admin) 26,304 #2 Posted November 20, 2007 Funny thing about tie rods.....one of my tractors( the one with dualies) gets a loose tie rod every 2 or 3 months. I always mean to check it periodically but I always forget till I see or feel it being loose. I have really leaned into the wrenches when tightening it but sure enough its loose again soon. I suppose I should just put a lockwasher on it.......one of these days. Mike..........the procrastinator Share this post Link to post Share on other sites
Curmudgeon 28 #3 Posted November 20, 2007 The rod ends are supposed to have lock nuts on them. Now lock nuts can only be used about once and still be called a lock nut. So if they've come loose, replace the lock nut with a new one or you can almost be guaranteed of continued looseness. Do I do that? Heck no, I just keep retightening them, and each time they hold less well than the time before. Dale Share this post Link to post Share on other sites
nylyon-(Admin) 9,054 #4 Posted November 20, 2007 Which end is getting loose, inside or outside? I don't think that I have any loose, but I have to admit, I really haven't checked either. Share this post Link to post Share on other sites
Sparky-(Admin) 26,304 #5 Posted November 20, 2007 For me its allways the outside. I suppose Dale is right and I should swap out the locknut.....but when I notice its loose its when I need the tractor so out come the 2 wrenches(1/2 and 9/16ths ) and I tighten her up. Mike........(probably loose right now) Share this post Link to post Share on other sites
CasualObserver 3,416 #6 Posted November 20, 2007 You know... speaking of ball joints... has anyone else tried these heim joints from McMaster-Carr? I've got one set on and I LOVE THEM... They're greasless, and wear great, and they're far and away more heavy duty than these little boogers... And at about the same price too! Opinions? Thoughts? Share this post Link to post Share on other sites
kj4kicks 154 #7 Posted November 20, 2007 Yep, we always used heim joints on the race cars. They don't flex under pressure, and the last a lot longer than the old style "ball and socket". As a bonus, they also take less force to rotate them. Eldon. Share this post Link to post Share on other sites
WheelHorse_of_course 101 #8 Posted November 20, 2007 In both cases mine were loose on the inside. Share this post Link to post Share on other sites
kpinnc 18,939 #9 Posted November 20, 2007 Jason, do they fit the regular tie rods? Kevin Share this post Link to post Share on other sites
CasualObserver 3,416 #10 Posted November 20, 2007 Mine did... they were the same thread size, I ordered to fit. You can order different sizes if you need... just go to McMaster-Carr and search for part 60645k44 it will bring up a whole page of the same part, with different stud and shank options... just pick what you need. the "General Purpose" one's are MORE than enough durability for garden tractors. I know a guy who went through three sets of the regular ones in about a year with a loader on a cub, switched to these, and hasn't had to replace them since. They do have even heavier duty options though, and of course the price reflects! 1 Share this post Link to post Share on other sites
Curmudgeon 28 #11 Posted November 22, 2007 Jegs has these too, several sizes. It's a referred source in some of the lawnmower racing forums, and where I got the ones I used on the racer I started. Dale Share this post Link to post Share on other sites
Mith 2 #12 Posted November 23, 2007 I replaced the tie rods with something slightly more heavy duty. Removed all but the slightest amount of play from the steering. Share this post Link to post Share on other sites
Curmudgeon 28 #13 Posted November 23, 2007 I've wanted to make heavier, adjustable tie rods like that for all my Horses for some time. But too many projects, not enough time!!!!! Dale, behind in Michigan Share this post Link to post Share on other sites
Greg B. 1 #14 Posted November 23, 2007 Gentlemen, I'm still in the learning curve for tractors, but I was a SCCA tech inspector, at the National level, for many years. I also rebuilt formula car chassis, for a while. If I may offer some comments regarding these rod ends. They don't like shock loads. They come in a multitude of qualities (The ones you get from Heim and Borgeson are among the best.) They should be installed in a double shear mount, but when used in single shear, the open side (top in Mith's photo) should have a washer sized to cover the whole diameter of the rod end. This captures the end of the linkage WHEN the bearing fails. I'm not saying don't use them. I love the things. Just give the application some thought. That C-series tractor, with attachments hung on each end, filled tires and weights, is knocking on a ton. Impact is mass X velocity squared. I'm sorry to come off like a wet blanket, but I have seen some scarey things come through the inspection station. Greg B. Share this post Link to post Share on other sites
Rollerman 291 #15 Posted November 23, 2007 Greg thanks for your concerns. I have to add I've been thinking about the heim joint idea too. I have to beleive a heim joint is tuffer than the ball & socket that Wheelhorse used, especially an old worn one? I have some friends that run an ebay bussiness makeing polished aluminium tie rods for ATV's & I may see if they can turn some down for me? May be a pretty cool dress up item for a tractor? Stephen in northern IN Share this post Link to post Share on other sites
Rollerman 291 #16 Posted November 23, 2007 Also Greg I didn't mean to come acroos like I was down playing your concerns, they are good tips. All things considered though a heim properly used I think would be better than my old tie rods that come loose. Has anyone peened the end of a tie rod with a ball peen hammer or a punch to sit the socket on the ball a little better. I have done this on some of the oldies & you get more life out of them. Stephen in northern IN Share this post Link to post Share on other sites
kpinnc 18,939 #17 Posted November 23, 2007 Aww Greg, you can't say things like that! Now I've gotta figure out how to modify my spindles to make them double shear! Just kidding of course- and the big washer is a good tip. I would imagine the guys with an FEL may want to pay particular attention to that... Kevin Share this post Link to post Share on other sites
Mith 2 #18 Posted November 23, 2007 Greg, agree with everything you say. Hadnt thought about putting a big washer on top incase it popped apart. There isnt really too much for it to hit if it does break though. To be honest, the whole front axle/spindle/tie rod setup needs replacing, it isnt really up to the loader. The 1/4" bar that the joint bolts onto on the spindle is bent too, just to give an idea how much of a thrashing it gets. I'm holding out for the time being as I want to add power steering, but I'll wait till the backhoe is done before I explore that too much. Share this post Link to post Share on other sites
kpinnc 18,939 #19 Posted November 23, 2007 Hey Mith, I can't remember the model, but one of the later models (300/400/500 series) had a power steering option. I saw it on one of the Yahoo groups awile back. kevin Share this post Link to post Share on other sites
Greg B. 1 #20 Posted November 23, 2007 I'm not trying to be a wet blanket. I have seen them fail, in just about every way imaginable, both subtle and spectacular. They are good devices when used with a little thought. I replaced them, on the car I was responsible for, at each chassis rebuild..., about three times a season, if the driver didn't do anything stupid. All 42 of them. The good ones are pricey and made in USA or England. You get, almost exactly what you pay for, with these things. Also, this is no place for the aluminum items. Spring for steel or stainless. The reason for the original WH design was to exclude as much dirt as possible, within the engineering and budget constraints of the time. These are bearings. Something else to think about Has anyone considered using automotive type tie rod ends? It would incolve a minimal amount of machine work, on the spindle arms, but would be more suitable for the environment Mud, dust and some things you really don't want to think about over lunch). I'll step down from my soap box, before I get thrown out. Greg B. Share this post Link to post Share on other sites
kpinnc 18,939 #21 Posted November 23, 2007 Greg, I'm sure you have no reason to worry about being "thrown out". The whole point of having the forum is to discuss things like this. I really like the tie rods that came up in this thread, and will probably try at least one set out. That said, given the points you made, they may not be the best thing to use in a high-load application such as a FEL or something similar, but for everyday use (mowing, tilling, plowing, etc...), they are probably fine. And you are correct- the open design of them is just an invitation for krud to get into them. All in all- good discussion on a problem all of us have to deal with on our tractors. Your experience with these is just another reason this forum works so well. I have a feeling that as parts become more difficult to get, such issues as this will be seen here even more often. Plus, a little ingenuity goes a LONG way when you're using 30-40 year old equipment. Kevin Share this post Link to post Share on other sites
Mith 2 #22 Posted November 23, 2007 Kevin, I'd appreciate any pics if you can find them of the power steering. That tractor is a 312, so any of the newer tractors is relevant. Share this post Link to post Share on other sites
nylyon-(Admin) 9,054 #23 Posted November 24, 2007 Kevin, are you thinking about the later 520's with the reduced effort steering? That is actually a gear reduction unit which was discussed here.... somewhere in the middle. Share this post Link to post Share on other sites
kpinnc 18,939 #24 Posted November 24, 2007 I just found the pics! It is a 520, and it has a "power steering" decal on the hood. I can't guarrantee it's factory installed, but it sure looks like it came that way: Sorry, it took a while to find these. They are in the "2003showpictures" group on Yahoo, in a folder named 'Nick857'. They were posted in 2003, but you may be able to contact him through the group. That's a single tie rod underneath it, from one spindle to the other- not sure I'd like that... Kevin Share this post Link to post Share on other sites
Rollerman 291 #25 Posted November 24, 2007 Kevin thats a custom setup there. Nicks brother works at a Horse dealer ship down south of Wakoneta, OH (not sure of the town or the dealer name?) But I thought I head it was dealer installed? I have seen pics of a similiar setup also done at another dealer. I'm deffinatley no mechanic...but with an orbital valve powere of the Eaton pump this probably would not be hard to do for someone that knew hydraulics? Very cool photo's & thanks for posting them! Stephen in northern IN Share this post Link to post Share on other sites
