WHEEL HORSE BILL
516h wheel horse
WHEEL HORSE BILL
Hi guys I am lookin at a 516H it has no motor and mowerdeck but it has wheel horse wheel weights and chains.I think all it needs is a motor and mowerdeck.this guy wants $150 for it. What is your opinion should i get it for that kind of money.
Indy w h
I'd say buy it !!! The WH wheel weights are worth that !!
WHEEL HORSE BILL
are the weights concrete.
Indy w h
Oh there not cast WH wheel weights ??!! If there in a black plastic shell they could be either sand or concrete
Forest Road
If they're black plastic weights there's nothing special about them. You could buy a new set of plastic weights and have Vinyl guy mak some decals.
But whats your purpose for buying this? Parts, full rest, worker?
kpinnc
Ask the seller why the engine was removed. If it was bad, then the tractor may be worth the money. If not, then the Eaton pump may be the problem, and the engine was used elsewhere.
The domestic 516-H and 518-H tractors used the lighter-duty 700 series pumps. They had about 1/3 of the output torque of the 1100 series pumps on the traditional "-H" model tractors had. Because of this, they were restricted against "ground engaging attachments". The problem with that was that most people used them with those attachments anyway, which greatly reduced the life span of the smaller hydrostatic pumps. The good news is that an 1100 series pump will bolt right in place of the 700, but you'll have to add hydraulic lift as well. The gearbox is the same regardless.
Just something to keep in mind. The tractor may be worth the money in parts alone, but it all depends on what you plan to use it for.
Good luck!
WHEEL HORSE BILL
This guy seems shady :eusa-think: . He told me that his buddy took the engine for his case tractor.I think the rearend is shot if you ask me and thats why he is sellin for 150 dollars.I think i'm goin to stay away from this one.Its been on cl for awhile and why hasn't it sold yet :confusion-shrug: shadyyyyyy.Thanks guys
WHEEL HORSE BILL :USA:
can whlvr
ya if you dont need any of the parts from it for your own machines i would walk from that deal
