dave24 18 #1 Posted March 1, 2012 Hello, does anyone have a diagram for where the chock, throttle, key, and push button go for on a 701 dash? Thanks, dave Share this post Link to post Share on other sites
dclarke 4,046 #2 Posted March 1, 2012 Left to Right, most guys have Choke, push button, key, then throttle. Share this post Link to post Share on other sites
rmaynard 15,731 #3 Posted March 1, 2012 Take a look at this: Scroll down to the sixth picture. Share this post Link to post Share on other sites
GlenPettit 1,717 #4 Posted March 1, 2012 In mid 1961, the position of the cables was changed on the 701 dash, to the outside positions to reduce the breaking and stress on the first plastic dash used by Wheel Horse, the inside two openings are slightly larger, 21/32"ID, and the outside two openings are 18/32"ID on the newer/later dash (for the two cables). (The ignition must be 2nd from right). Almost all 701 dashes have broke & cracked over time. The 701 Dash you just purchased from us is the newer/later version. Be careful and don't over tighten the screws (use Stainless Steel & washers). Good Luck, Glen Share this post Link to post Share on other sites
