4SPEED
1965 6hp Tecumseh (Will Not Start)
4SPEED
it has new points, good plug, cleaned the carb, new gas , new gas line & filter. It has good spark..
it'll hit One time, then it just cranks. I think its getting to much gas. the plug is wet...
also,, does anyone have a pic of how the governor linkage is hooked up?
tunahead72
Just off the top of my head ...
Did it run BEFORE all this work?
Have you done a compression check?
AMC RULES
Not sure, is that the H60 Tecumseh motor? :dunno:
I recently uploaded the H60 parts manual in the files section...might help you out.
pfrederi
Did you put in a new flywheel key? They are a soft aluminum alloy designed to shear. Did it backfire when you first tried to start it? Backfiring can deform the key and then you will have a very nice spark but occurring at the wrong time.
Terry M
Could the carb. Float be stuck? Sounds like a lot of fuel .
4SPEED
no it didnt run, no spark. and no compression check.
thanks, that will help a lot. and yes it the H60 sorry I left that info out.
no I did not. kind of what Im thinkin . its firing to soon or late. I put a new plug in it , and now it'll run about 3 or 4 sec. and yes it has poped outthe carb a few times. not all the time.
I dont think so, but yes, Sounds like a lot of fuel
here is some pics of my 6 hp tecumseh on my 65 lawn ranger hope this helps!
http://i1137.photobu...s1/IMG_2064.jpg
http://i1137.photobu...s1/IMG_2060.jpg
thanks , you the man.............
rockinhorse
4speed Just went thru the same thing. I got a carberator rebulid kit and rebuilt the carb. Make sure you clean all the vents real good . The float is tricky to set . Once i got it set right it starts good. I also put a new plug in . I used a NKG 3510
4SPEED
what is the carb kit and flywheel key going to cost?? and who sells it? soaking money into it , I dont what to do when its only use will be to drive it in the yard.
rockinhorse
4SPEED carb rebuild kit cost me almost $15, couple cans of carb cleaner $6 to $7. I got my carb kit from carquest. You can get flywheel key at auto store maybe $1. besure and take the old one to get one the same.
karl
4SPEED
are the auto parts store carb kits ethanol safe. I know the kits they sell for my 70's cars Q-jets are not. the gaskets and o-rings brake down in the ethanol.
todays gas is hard on the old engines
I check with the auto store tomorrow.
