speedyleedy
What type of hydro fluid used in a 1077 ?
speedyleedy
I need some help, i need to know what type hydro fluid to use in my 1077 automatic i would be thankful if someone could help me !
Trouty56
Most likely a Dexron type ATF fluid. That is unless it has been changed to motor oil. Check the color of the fluid. If it is red then it is ATF. Use a Dexron III type. If it is motor oil then 10-30 or 40.
If you are not sure then ask for more clarification from the forum.
speedyleedy
Thanks for your reply trouty56 ! It looks like motor oil .
