BIGKUZ
1961 551 restoration
BIGKUZ
Need a wiring diagram for what a belive is a 1961 551 suburban with a tecumseh Model # H55d-2113 motor . Also need the round key switch mounting plate, any ideas ?
CasualObserver
Here's the 551 wiring diagram. (click to enlarge) Post a wanted ad or watch ebay for that switch plate.
AMC RULES
Hey Kuz... :WRS:
:wwp:
  • Similar Content
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • grasscuts
      By grasscuts
      Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
    • jakester
      By jakester
      hello all I'm a new owner of a 312-8 tractor, have starting problems, came across a very small, what I believe is a relay between the battery and the dash,its about 2/3rd size of a cube of sugar silver on the outside blue on top with a hole bout the size of a pea, theres 6 pins with wires connected to it on the bottom do not know what this is any thoughts? I cannot determine the exact year of this machine for there is no tag anywhere only tag on engine kohler magnum md #m12s   ser# 170370459  spec#  471527  I figure its mid to late 80s to early 90s. of all the wiring diagrams ive looked at it does not show any thing like what I just described also can that little circuit board be removed that's like a test point for idiot lights? any help would be appreciated  jeff
