JamesBe1
Stuck Needle Seat
JamesBe1
I took the carb off my my D-180 yesterday and soaked it overnight in Berrymans. It came out very well. While disassembling it, I was unable to get the needle seat out. I left it in and figured that I would find a way to remove it after it's much cleaner. So after cleaning it up today, I have still not been able to get the needle seat out. I am starting to gall the brass. I have tried every screwdriver that I have, but no matter how hard I turn it, the brass wants to mar instead of the threads coming loose.
So, my questions to the experts are:
Does anyone know of a good method for getter a stuck needle seat out?
Will I have to drill it out and replace it?
If so, are there specific sizes that I need to worry about finding?
Any help that you guys can throw my way would be appreciated.
Thanx,
James
Martin
are you talking about the main jet for the high speed needle?
not sure what carb you are rebuilding, but if its similar to the smaller kohler carbs 10 hp etc then i would just leave it be. you dont really need to remove it, unless its now damaged.....
is this it?
can whlvr
ive never drilled a seat out,but if you have too id consider taking it to a machine shop,it will have to be very precise to acept the new seat,there are pastes you put in the slot that add grab to the screw driver,are you sure you even need a new seat,id be trying it before i went to that much trouble,good luck,im sorry i dont remeber the pastes name,but it has grit in it and supposedely works good
JamesBe1
is this it?
Thanx Martin. Yep, that's it. I have always taken them out and cleaned them before dozens of times. Never had a problem like this one before. I am on the verge of damaging it. Don't want to go much further unless there is a better trick to it, or a new one can be easily had.
I do have a donor carb from a 14HP kohler K series, but I don't know if they are interchangeable, or have specific specs.
JamesBe1
Thanx can whlvr, I have a drill press and am able to drill it out if need be. I have several easyouts that should be able to pull it out after I enlarge it enough. I think I'll look around for the paste that you are talking about.
Martin
ive tried to get them out in the past, but i usually give up on them before i open a bigger can of worms. the last couple carb rebuilds i just left them alone. if you dont get it out cleanly, and damage that area, the carb will end up junk.
JamesBe1
I've never had a problem getting them out in the past. Dozens of times. This one has me stumped. I might just take your advice and not mess with it anymore. Been looking around the internet, and can't seem to even ID the part except for people wondering how to get them out and/or get new ones.
James
JamesBe1
this site has some good info.....
http://www.gardentra...om/carbfuel.htm
Thanx Martin. I am familiar with Brian's website. I took the time to read that page more thoroughly this time. Seems you can't get those seats at all, and he has them custom made. He advises to just leave them alone. I think that is what I am going to do. Hopefully I didn't mar it too much.
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
