1maidenfan
D series PTO clutch faceing
1maidenfan
Does any one know where to get the refaceing material for the PTO clutches?
Thanks.
MrHorseMan
I think I have a couple parts clutches you can have when you come up
helimech99
I don't what the clutch looks like on your model, I have a Raider 12. McMaster Carr (mcmaster.com) sells 15" by 15" sheets of clutch material for about fifty dollars. They have different thicknesses and friction ratings available. I bought a sheet of 3/16" thick medium friction material, traced the pattern on it and cut it with a fly cutter on my drill press then drilled the rivet holes, countersunk them, put a very thin coat of epoxy on the back of the surface and installed it with brass flat head rivets. It is as good as new and has been running with no problems at all. It sure beats hunting around for a used clutch that may be in no better shape than the one you have. You can get four clutch pads from one sheet. I installed one, kept one for a backup, and sold the other two with rivets for $25 each. Total cost to me...nothing but a couple of hours work. They also have 7 1/2" by 7 1/2" sheets for about $24 but then you only get one clutch done.
Hope that gives you an alternative to buying a used clutch.
1maidenfan
Thanks , will check when I get there,
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
