Butch 194 #1 Posted January 25, 2012 I've never plowed before. I have my plow attached to my WH. I am using the solid bar for the lift mechanism? Is this bad? Should I be using the chain instead? I have a hydraulic lift C-175. If I go in a small valley and hit the asphalt with the plow am I gonna do damage to anything like the hydraulics from trying to raise the blade up? Does the chain go in the same hole that the solid bar goes in? Thanks Share this post Link to post Share on other sites
can whlvr 994 #2 Posted January 25, 2012 personally i would leave as is Share this post Link to post Share on other sites
rmaynard 17,562 #3 Posted January 25, 2012 I have always used a chain. I'd rather have just the plow move with each little bump than to have the shock transferred to the lift mechanism. Mine is a manual lift. Share this post Link to post Share on other sites
Ken B 3,203 #4 Posted January 25, 2012 I'm with Bob. Share this post Link to post Share on other sites
truckin88 104 #5 Posted January 25, 2012 I use to own your 175. And it is a beast plowing. I like the solid lift bar on manual lift machines, I can let it float at the height adjustment or the lift adjustment. On a hydro, I think I'd rather a chain, as there are more parts to be concerned with. -- Just a note, since that machine is an early KT17 w/ a teardrop air cleaner and not a round one w/ hot and cold settings, the flywheel will draw snow into the carb and ice the carb. I plowed with that machine and the way I fixed it was using some HEET in the fuel, never had an issue after that. Share this post Link to post Share on other sites
Sparky-(Admin) 26,277 #6 Posted January 25, 2012 All three of my plows are hanging by chain. They weigh enough for snow removal. The solid lift link might be better for dirt pushing. Mike......... Share this post Link to post Share on other sites
IthacaJeff 151 #7 Posted January 26, 2012 I have a solid link and toyed a while with a different plow with a chain. Vastly prefer the solid link. Much more versatile, more control. I have a manual lift and sometimes the lift lever does get jerked around. I might not choose to use the solid link with a hydraulic lift. Jeff Share this post Link to post Share on other sites
can whlvr 994 #8 Posted January 27, 2012 it doesnt seem to hurt the tractor too much or i wouldnt do it,i like it because when the snow builds up on warmer days if i want to clear the deep stuff i have hydro,but i do admit that i also have one with the manual,but it has the solid also Share this post Link to post Share on other sites
