dadstractor1
engine oil d180
dadstractor1
need too cange oil in d180 what kind how much :confusion-confused: dadstractor
Sparky
What type of oil will depend on where you are. In the cold states ( I'm in Ct.) we run 10w-30. When spring comes around its back to 30w. Whats the temps where you are?
Mike...........
stevebo
send me your email and I will send you the manual for the same machine (auto 18). It is calling for the following:
below 0 degrees 5w20
0-30 degrees 10w-30
over 30 degrees sae30
Does not say how much. I would think no more than 2 - 3 quarts max.
Trouty56
3 quarts is mentioned in the Kohler manual under the oil change section......
Sparky
0-30 degrees 10w-30
I don't think I want to be out on my tractor if its below 0 degrees. Seat time ain't that important!
Mike...........
dadstractor1
do not use too much in cold wether fixed loader pump mount today and looked at dipstick and looked like tar :eek:
