dadstractor1 5 #1 Posted January 23, 2012 need too cange oil in d180 what kind how much dadstractor Share this post Link to post Share on other sites
Sparky-(Admin) 21,085 #2 Posted January 23, 2012 What type of oil will depend on where you are. In the cold states ( I'm in Ct.) we run 10w-30. When spring comes around its back to 30w. Whats the temps where you are? Mike........... Share this post Link to post Share on other sites
stevebo-(Moderator) 8,264 #3 Posted January 23, 2012 send me your email and I will send you the manual for the same machine (auto 18). It is calling for the following: below 0 degrees 5w20 0-30 degrees 10w-30 over 30 degrees sae30 Does not say how much. I would think no more than 2 - 3 quarts max. Share this post Link to post Share on other sites
Trouty56 565 #4 Posted January 23, 2012 3 quarts is mentioned in the Kohler manual under the oil change section...... Share this post Link to post Share on other sites
Sparky-(Admin) 21,085 #5 Posted January 23, 2012 send me your email and I will send you the manual for the same machine (auto 18). It is calling for the following: below 0 degrees 5w20 0-30 degrees 10w-30 over 30 degrees sae30 Does not say how much. I would think no more than 2 - 3 quarts max. I don't think I want to be out on my tractor if its below 0 degrees. Seat time ain't that important! Mike........... Share this post Link to post Share on other sites
dadstractor1 5 #6 Posted January 23, 2012 do not use too much in cold wether fixed loader pump mount today and looked at dipstick and looked like tar :eek: Share this post Link to post Share on other sites
