Kevin Benfer 2 #1 Posted January 22, 2012 i have a 502 with a split fuel tank is there anywhere to get the gasket for the tank or should i just make a new one. thanks in advance Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted January 22, 2012 A 502 should have the one piece tank which is a much better design, looks like someone has put a '63 or '64 tank on your machine. Part # 4452 available through your Toro dealer, or here is one on Amazon: http://www.amazon.com/Replacement-part-Toro-mower-GASKET/dp/B003X9K39S Be very careful undoing the screws, they are prone to breaking off as you try to undo them. Share this post Link to post Share on other sites
64s 83 #3 Posted January 22, 2012 I believe its still avaiable from Toro. And every once in a while they show up on ebay. Share this post Link to post Share on other sites
WH854 45 #4 Posted January 22, 2012 i have a 502 with a split fuel tank is there anywhere to get the gasket for the tank or should i just make a new one. thanks in advance You can still buy one from Toro P/N4452 They are about $20.00 Chas Share this post Link to post Share on other sites
