nylyon-(Admin) 7,183 #1 Posted January 21, 2012 Snow and the %@$&*#! throttle cable &^#(!&*# broke. @*!& IT! Share this post Link to post Share on other sites
Kelly 1,029 #2 Posted January 21, 2012 Mine was froze and would not move this morning on the 520, I figrued if I tried too hard I would break it, I used a hair drier to thaw it, but after letting it set for a hour it will not move again, it's coming off tomorrow. Share this post Link to post Share on other sites
nylyon-(Admin) 7,183 #3 Posted January 21, 2012 I needed the exercise anyway, that extra 20 from Thanksgiving has to come off! Share this post Link to post Share on other sites
rmaynard 15,309 #4 Posted January 21, 2012 Snow and the %@$&*#! throttle cable &^#(!&*# broke. @*!& IT! Hey, this is a family forum. My B-100 has been sitting outside the garage this winter, but covered. The temperature was 24 this morning with an inch of ice covered snow. As usual, she started right up, and no cable problems. That's because I pulled the cable a couple of years ago and coated the wire with anti-seize. However, I did start to send up smoke signals after two times out the drive and back. That's when I remembered to release the parking brake. Should have had that extra before I got started. Share this post Link to post Share on other sites
JoeMonag 1 #5 Posted January 21, 2012 I hate when taht happens. Had a cable freeze up on my 26" two stage walk behind, for the chute deflector. Put it in my (insulated) shed with a 500 watt quartz lamp near it, for an hour or so and got it freed up. Joe in Norton Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #6 Posted January 21, 2012 I believe I would have zip-tied the throttle open before I would have shoveled that much. Which tractor, Coach? A trick that works on the "braided" cables that might also help these is to soak them in ethylene glycol. :handgestures-thumbup: Share this post Link to post Share on other sites
nylyon-(Admin) 7,183 #7 Posted January 21, 2012 It's the 414, I should have taken the 416 with the blower on it out of the shed. I need to lose some weight anyway so I shoveled the entire 250' of driveway. Share this post Link to post Share on other sites
speedyleedy 205 #8 Posted January 21, 2012 Mine work great this morning on my 857 as i was plowing about 6" to 8" of snow ! :ychain: Share this post Link to post Share on other sites
SALTYWRIGHT 859 #9 Posted January 21, 2012 I PUT A LENGTH OF PLASTIC HOSE OVER THE CABLE AND BUT SOME OIL IN THE HOSE. IT WILL ALWAYS WORK WHEN IT IS VERY COLD. RUSS Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #10 Posted January 21, 2012 It's the 414. That figures..... I have three or four new throttle "assemblies" for your 416. :disgust: Share this post Link to post Share on other sites
can whlvr 993 #11 Posted January 22, 2012 i hear your pain karl,my 414,s freeze up when i use the snow blower on them,its a bad design to have the cables facing up and snow melting on them from the blower and the heat of the engine melting the snow Share this post Link to post Share on other sites
MaineDad 85 #12 Posted January 22, 2012 Been there and done that! PIA!!!!! Share this post Link to post Share on other sites
nylyon-(Admin) 7,183 #13 Posted January 22, 2012 I should have taken the 416 out to play, would have made my day far more enjoyable too. Share this post Link to post Share on other sites
