smoreau 658 #26 Posted January 21, 2012 All but 1 hitch went out today and if you ordered 1, check your pm's for the tracking #. The last hitch is brrly1's and I am waiting for the other 520xi hitch to get to John to check fit. This way brrly1's hitch should fit with out any mods. planning on another hitch build in a few weeks. Share this post Link to post Share on other sites
oneroadkingman 53 #27 Posted January 25, 2012 I must say that your receivers are really nice looking,and i like that you left the factory hitch in place, my question is how much can u really pull o haul weight with it. also building one out of 1 1/4 tube be ok or too light duty just wondering thanks Share this post Link to post Share on other sites
SgtBob 27 #28 Posted January 27, 2012 I am interested in one for a 416H. Please let me know if you still have any available. Thanks, Bob Share this post Link to post Share on other sites
GlenPettit 1,717 #29 Posted January 27, 2012 It's a Class II Hitch, rated at 5,000 pounds. Scotts hitch is extremely well made & engineered. In my opinion, a Wheel Horse can tow much of that on reasonably level ground. I've seen 2.5 ton boats and trailers being moved easily by 12 hp Wheel Horses, more weight in/on the tractor will make towing much easier (on wheels & in front too). I am also using the hitch with as a drawbar (1/2" pin & a brass insert to reduce the hole), really like the extra 8" extension for turning & backing up (the staff/pole is so I don't hit my shin, and I have a light-weight battery red flashing light for snowplowing, just above my head/hat on that pole). Tires are filled with 'Rim-guard' and there is a pair of red inside Wheel Weights on the rear wheels (total, extra 250#) Share this post Link to post Share on other sites
shallowwatersailor 3,214 #30 Posted January 29, 2012 Being very pleased with my original purchase of the 1st run of 2" hitches for my C-105, I asked Scott if I could get one for my main worker. Without the luxury of being able to see my tractor in person and with only a number of my measurements, photos, and phone conversations, Scott expertly fabricated the hitch for my 518xi. The overall dimensions of the 518xi required that the hitch to be a bit larger in each direction. Only the pin cavity for the original Wheel Horse-style hitch in the transaxle casting is the same. It fit PERFECTLY! The bolt holes for the rear Attach-A-Matic lined up exactly and the four interfering bolts that mount the transaxle to the frame were cleared. No modifications were needed. He really is a craftsman. Just to check, I attached my winch plate adaptor that I am going to mount additional weight on and then stood on it. It really is sturdy! By the way for the purists , that's a Wheel Horse logo below the NH. :wh: Share this post Link to post Share on other sites
CRE1992 135 #31 Posted May 3, 2012 What kind of tires are those? Share this post Link to post Share on other sites
GlenPettit 1,717 #32 Posted May 4, 2012 Firestone 23º Ag tires, filled with RimGuard. Actually a smooth riding lug. Share this post Link to post Share on other sites
sschoener 0 #33 Posted May 16, 2012 I just picked up a 310-8 and I would love one of these if you are going to build again. Share this post Link to post Share on other sites
zieg72 209 #34 Posted May 16, 2012 Scott. Can you share a picture of the 2" receiver tube you use before it is painted? I would like to see how the outside end is attached. I had to remove mine because I couldn't load it on my truck with the tiller on it because it sticks out enough to hit the gear box. I want to take off the end and re-attach it after I shorten it up within 1/2" of the pin. Thanks in advance Share this post Link to post Share on other sites
smoreau 658 #35 Posted May 17, 2012 I buy the tubes with the outside crimped from Rigid Hitch. They are pry made and cost about $16 shipped to me. You can cut that end off and get a 1/2" long piece of 3"x1/4" wall tube and weld that on the shorted tube. Share this post Link to post Share on other sites
KohlerJohn 2 #36 Posted May 17, 2012 Hi, I sent a message about purchasing one for a 312-8. Just let me know when one is available. Looks great!!! Share this post Link to post Share on other sites
CRE1992 135 #37 Posted May 19, 2012 Hey Scott, I am interested in one of these hitches, when will be the production of the next set? I also sent you a PM. Thanks, Charles Share this post Link to post Share on other sites
falvarado62 0 #38 Posted December 7, 2013 Hi, I just purchased a C120 Automatic Wheel Horse. Do you make a 2" hitch that works with that model? Thanks, Frank Share this post Link to post Share on other sites
posifour11 723 #39 Posted December 7, 2013 Here's the new thread. I love mine. Worth every penny. Share this post Link to post Share on other sites
Stephen226 0 #40 Posted April 5, 2014 Do you still build these? I would be interested in one for my 312-8. Thanks, Steve R. Share this post Link to post Share on other sites
