Suburban 550
701 Hood and Belt Guard Repairs
Suburban 550
As many of you know when I bought my 701 the hood was cut and hinged and the belt guard was chopped, with the front mounting tab and belt guide missing. I tried to keep the repairs to a minimum and still have that patina look, but it is a question of where to stop. This weekend I had a little time on my hands and ended doing a little more than I intended. Hope you enjoy.
Pics of what I started with (hinged hood)
Hood mig welded back together and slots in rear of hood repaired
Went a little overboard and decided to remove all the dents and totally strip all the paint. Pictures are of the hood stripped with the decals still in tact and all the repair areas feathered in with body filler. The decals were later removed
After a final sanding 2 light coats of Dupont Etch primer was applied to the bare metal for a good adhesion
Next 3 coats of high build primer was applied to take care of any small imperfections
On to the belt guard and what it looked like before I started
Front mounting tab, belt guide and missing chunk out of bottom of guard all welded back on and stripped down to bare metal
All dents are removed and repair areas are feathered in with body filler
After finishing sanding etch primer is applied to bare metal on both sides
And finally the high build primer applied
Last thing was the replacement gas tank. The holes where the hood bolts on were messed up in the old tank and fortunately I had another good tank. Got that prepped also.
Now the next question is where I go from here. I got a little more involved than I wanted to but the hood, belt guard and gas tank just needed to be done to make it look presentable. I have the complete set of decals for it but didn't plan on doing a complete paint job on it. Any suggestions ???
dclarke
Man, you sure do nice work Ray. I think I'd have to do the whole tractor but that's just me, I'm sure whatever you do it's going to look GOOD. The belt guard on my 701 doesn't have the tab sticking out the front at the bottom, do you know if it's supposed to? Nice work! :thumbs:
sorekiwi
Very nice work Ray!
But now you've opened that can of worms - I have no idea how you are going to get it closed!!
My prediction is that the rest of the tractor will be in pieces by the end of the week...
Suburban 550
Mike, my thoughts exactly about the can of worms. An all original, good runnin' 701 like that doesn't show up often and that is the way I wanted to keep it pretty much as it was. But you know in life there are somethings that just eat at you and you just have to do something about it. You and Denny are probably right about redoing the whole tractor over which seems like the right thing to do at this time unless someone invents that rustic looking patina finish before I start rippin' the rest of it apart. Denny, as far as the belt guide tab at the end of the belt guard, I asked the same question on this forum with no reply from anyone. Duke sent me a picture of an original belt guard off his 701 which had the tab on it. I've also seen the belt guides bolted on the motor which mine had neither. Which one is correct, I still don't know the answer. All I know mine wouldn't shift without it, so that is the way I went.
dclarke
Ray, on the belt guard tab, I may add that to mine. I'm sure it has to help.
sorekiwi
Not sure how you could apply this to bodywork, but here is an interesting article, written by a guy who restores antique engines. It is technique on how he makes the new parts look old.
http://www.rustyiron.com/Articles/antiquefinish.html
And another by the same guy where he uses electrolysis backwards - putting shiny new parts in the tank to make them rusty!!
http://www.rustyiron.com/Articles/reverseelectroly.html
Personally, over the last year or so, I have really started to go off the shiny red tractor look. I've become a huge fan of the unrestored tractor!
Suburban 550
http://www.rustyiron...iquefinish.html
http://www.rustyiron...eelectroly.html
Very interesting, Mike. I'll have to try that, but not on the hood, belt guard or the gas tank yet, but something old I have layin' around. Thanks
buckrancher
total strip and repaint Ray
you know you want too
Brian
Suburban 550
Brian
Brian, if I did something else for a livin' it would be alot easier to do. You can ask me to help you build a house, but don't ask me to do body work after hours. No wonder why you see a plumbers pipes leakin' in their own houses and a carpenters siding fallin' off, it just becomes overwhelming and I have to force myself to do it. As crazy as it may sound, it's the truth.
AMC RULES
Looks great so far! :icecream: At this stage though, I'd vote for the total resto as well. :deadhorse:
Kelly
I here you on the doing body work after doing it all day at work, I feel the same way, BUT, that would be a nice tractor to restore, or I'll trade you a belt guard and hood in nice orig. shape with bumps and scratches for those ready to paint ones :hide:
stevebo
Ray,
You do wonderful body/paint work. When I saw you looking at that tractor I knew it would end up going down this road.....
can whlvr
since you asked for opinions i think you are in so far that you may as well do the whole machine,it will be worth it when she looks better than new,nice work too,go for it
Suburban 550
Glad it's not only me that feels that way about body work, Kelly. Seems like you have a 701 restoration project in your future plans. Thanks Don, Steve and Craig for your advice and compliments. A total restoration at this point seems like the way to go. The shop I work at now uses Sikkens paint which I have never used before. I talked with our painter yesterday and he made me an offer I just couldn't refuse. He told me to get everything prepped and bring it to the shop and he would paint it with a Sikkens single stage polyurethane paint similar to Dupont Imron which is supposed to hold up really well. All our wreckers and rollbacks are painted with it and still look good after many years in the weather. For now I will take the hood, belt guard, and gas tank and wet sand them with 600 grit , recoat with Sikkens Color Build primer wet sand again with 600 grit and since we have our own mixing system, try to find an International Harvester red or a color close to it and paint all three pieces. After that it's up to me to find the time to tear it down and get everything ready. This will be the first restoration I haven't painted myself, but things could change.
dclarke
Glad to hear it Ray, work your magic buddy! :thumbs:
Jake Kuhn
It looks great! :bow-blue:
MikesRJ
Keep going Sluggo. I wish I had the time. Great work. :angry-banghead:
kpinnc
Ray, I have a 701 hood and a RJ hood that needs your attention.... :ychain:
That really is some great work!
Suburban 550
Mike, I wish I had the time, also. Between running my wife to doctors, hearings and therapy, my hours have been limited. Kevin, soon as I retire, send me your hoods. :ychain: Good to see you posting again. :thumbs: Tractor is all back together with all the repaired pieces still in primer and for now I will put temporary decals back on and paint the lettering on the hood and that will be it for now. I hate to rip it all apart and not have it ready for the big show in June. I will be posting some updated pictures in the near future.
AMC RULES
Looks awesome so far, can't wait for another pict update/progress report. :banana-wrench:
  • Similar Content
    • buzzard440
      By buzzard440
      1961 701 for sale complete and original w/ mower deck. Runs but needs TLC.
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
