Callen 64 #1 Posted January 1, 2012 Have a leaky ram. Can't seem to find any info on my '70 Charger 12 Auto with hyd lift. I've searched here and found info on newer tractors. Can anyone point me in the right direction? Share this post Link to post Share on other sites
pfrederi 18,314 #2 Posted January 1, 2012 If it is original it is probably welde piston type. (There are at least 3 styles). Is your clevis threaded on the end of the shaft and have a single set screw? If so the repair kit is 101699 for only $50+. All you get is a couple of O rings a couple af backer rings and a seal. Take it to Hydro repair place I will bet they have the rings for alot less money. Also they will check for damage that may make teh cylinder unuseable (if you buy the kit and the shaft or bore is damaged you wasted your money. There is a manula form WH I have the download but don't remeber where I got it. PM me I can send it to you Share this post Link to post Share on other sites
Callen 64 #3 Posted January 2, 2012 Thank you, Paul. Went out and cleaned it good. No leak from the ram, it's coming from the swivels in the hoses. Do these usually leak there? Share this post Link to post Share on other sites
pfrederi 18,314 #4 Posted January 2, 2012 If it is the swivel itself that is leaking you will have to replace the hose. (Take the old hose to a hydro shop) If it leaks around the fitting where it screws into the valve bank or the cylinder remove it and check the O ring. (Have a pan underneath as you will get ATF running out) Share this post Link to post Share on other sites
can whlvr 993 #5 Posted January 3, 2012 the swivel seems to allways go first on these,i bought a new to me valve and cylinder and they leak too :banghead: Share this post Link to post Share on other sites
Callen 64 #6 Posted January 4, 2012 What is the purpose for the swivels? Think I'm going to put adapters on it and use a flare type fitting on the hoses. Share this post Link to post Share on other sites
