IthacaJeff 151 #1 Posted December 30, 2011 Hi all: Had a little time yesterday to look through the Kohler manual for fun, and noted that my Kohler K341 and M20 (on my Deutz-Allis 1920) require head removal at 500 hrs to have carbon buildup removed and valves checked. Of course, a new head gasket is necessary when putting it all back together. I've never done this, but then again, none of my tractors were purchased with less than 700 hrs. How many of you have done this on a "routine" basis? Jeff Share this post Link to post Share on other sites
Anglo Traction 761 #2 Posted December 30, 2011 Hi Jeff, I carry out this procedure religiously on any engine that comes into my possession, irrespective of it's history. I have seen the damage that lumps of Carbon can do, as well as affect performance, causes 'Hot Spots' and therefore Cooling. For the sake of a Gasket and an hour or 2, it's a 'No Brainer' for me. Having said that, most modern fuels significantly reduce deposits, so modern engines are less affected. Also with use of additives, they stay cleaner longer. Most of mine are 30+ years old when I've aquired them. Regards. Share this post Link to post Share on other sites
Kelly 1,029 #3 Posted December 30, 2011 I think 80% of the kohler single cyl. engines that pass through here need a head gasket and carbon cleaning, ones I sell (unless beaters) or my keepers get that done, check to see if the head is flat at the same time, be sure to use a torque wrench and follow the pattern, and re check after a hour or so of run time, let it cool at least a hour before re torquing . Share this post Link to post Share on other sites
AMC RULES 37,132 #4 Posted December 30, 2011 I'm ashamed to admit I'm pretty clueless to the whole process too Jeff. I've seen it discussed in great detail but wasn't paying attention. A link to a previous thread would probably be most helpful, but the best I can do right now is this one instead. At least I brought something to the table. http://www.ebay.com/...-All-Categories Share this post Link to post Share on other sites
AMC RULES 37,132 #5 Posted December 30, 2011 Ok, found us some reading material Jeff. http://www.wheelhors...h&fromMainBar=1 Well I guess that method didn't work huh? Try kohler head gasket in the forum search window, lot's of reading material on the subject comes up. :thumbs: Share this post Link to post Share on other sites
sorekiwi 761 #6 Posted December 30, 2011 I am always srprised that most of the "new" ones to me have headbolts that arent as tight as they should be - a result of the head gasket compressing. So they usually get a clean up straight away, and a retorque after the first running. However after that I dont keep track of the hours (I just change the motor oil in the spring and in the fall). I think even with my mowing tractor I would put less than 100 hours on a year. So in 5 years (500 hours) I'd probably be wanting to do a valve job and a clean up anyway. Share this post Link to post Share on other sites
Shuboxlover 478 #7 Posted December 30, 2011 This is what I found when I took the head off my 7HP Kohler... Share this post Link to post Share on other sites
IthacaJeff 151 #8 Posted December 30, 2011 I was really hoping to hear something like. . . ."nah, never done it, its just a legal/warranty thing with Kohler. . ." Guess I've got a new job coming up in the spring. Jeff Share this post Link to post Share on other sites
smoreau 658 #9 Posted December 31, 2011 I was really hoping to hear something like. . . ."nah, never done it, its just a legal/warranty thing with Kohler. . ." Guess I've got a new job coming up in the spring. Jeff I would say 90%+ of the people that buy a kohler engine will never consider that as a thing that they would do. Most just run it tell it dyes and take it in to someone to fix it. that would be the norm, but some do every thing that the the manufacture would like done when its due. As for me, my 875 never had the head removed sense it was new before I restored it. still needs to come back apart and have them moly rings replaced with kohler ones. But thats another topic. Share this post Link to post Share on other sites
HorseFixer 2,012 #10 Posted December 31, 2011 Yep, everyone that comes home gets heads removed, carb removed cleaned, points, condensor, Plug and a good going over. filters replaced if needed, oil change all of this is depending wether its a keeper. If the engines bad AWE WHAT THE HELL Drop a Grand ~Duke 1 Share this post Link to post Share on other sites
tunahead72 2,424 #11 Posted December 31, 2011 Jeff, I do the head and combustion chamber cleaning every spring on my main mower ('86 310-8). I've never done the head flattening procedure, only because I didn't know how until this past summer, but I'll do that next spring as well. The procedure is described in the Kohler service manual, which you should be able to download from their web site (and other places) if you don't have a copy yet. There's also a more comprehensive write-up on head gasket issues that I've found useful, written by a guy named Matt Gonitzke and available on his web site here: http://mgonitzke.net.../headgasket.pdf Matt has written up some other procedures for Kohler engines, they're on his site also in the "How-To" section. Be aware that he specializes in Cub Cadets, so you'll see references to CC tractors that won't apply to Wheel Horses. The valve adjustment is also worth doing every once in a while, especially if you don't know whether it's ever been done on your particular machines, or if you think you're hearing any valve noises. That procedure is also described in the service manual, and it's more involved (usually requires removing the carb), but it's not real difficult. I know I've seen some threads here that helped me, I'll try to find them if you're interested. By the way, this stuff should also apply to the K241 that I'm assuming is in your 310-8. Share this post Link to post Share on other sites
can whlvr 993 #12 Posted December 31, 2011 i too look at every one that comes in,one of the last ones that had no compression was carbon,if you read brian millers pulling site,he says you can reuse a head gasket if its in good shape,i think you need some gasket compound of some type,ive reused head gaskets :hide: Share this post Link to post Share on other sites
Shuboxlover 478 #13 Posted December 31, 2011 If the engines bad AWE WHAT THE HELL Drop a Grand ~Duke :laughing-rofl: Share this post Link to post Share on other sites
Mith 2 #14 Posted December 31, 2011 I think its because most of the people on here are here because they are enthusiasts, so are more likely to take care of their engines in the way that Kohler suggests. As Scott said, I bet most engines never have much more than basic servicing done, some not even that! Personally, I have never taken the head off as part of routine maintenance. It is just a lawnmower engine at the end of the day! In theory its a very easy job, but experience tells me that it can get very tricky very fast! Share this post Link to post Share on other sites
buckrancher 2,679 #15 Posted December 31, 2011 I was really hoping to hear something like. . . ."nah, never done it, its just a legal/warranty thing with Kohler. . ." Guess I've got a new job coming up in the spring. Jeff you should be all set for awhile Jeff I did that when you had her at my house Brian Share this post Link to post Share on other sites
IthacaJeff 151 #16 Posted January 1, 2012 Hi Brian: I figured you had done that to the 416 -- she's the least of my worries! My inquiry was really inspired after looking through the Kohler manual I picked up to go with my Deutz Allis (Sunstar) with the Magnum 20. I just picked up this tractor to do the main mowing chores (60" deck) and figured in the spring I'd give it a good going over. The complexity of this machine versus the WHs is daunting . . . but the price was right. Anyway, I guess I'll hit the single head on the M10 of my 310-8 then tackle the dual heads on the M20. A couple of warm dry days in spring should be perfect. Thanks, Jeff Share this post Link to post Share on other sites
