Shuboxlover
Stupid question....
Shuboxlover
Where do I fill the tranny in my 753?
Is it the pipe plug on the lower left side of the tranny? (not the one on the bottom, where you drain it) but the one on the left side a couple inches up form the bottom.
WH854
I filled my 854 by taking the shifter out and filling it that way 1 1/2 qts
Chas
Trouty56
I filled mine with the plug on the side. I read where you drive the left side of the tractor on a 2X4 and fill the tranny till the oil comes out the side plug. I guess removing the shifter might be easier but I didn't know of that.
boovuc
Hi Shubox!
This is cut and pasted from the manual on the 633/653/753 manual.
Check
transmission oil level after every 40 hours of operation. Remove
oil filler plug at left rear side of the
transmission and fill to level of hole with a good grade of S.A.E. 40 gear or engine oi. Drain and refill
once each year.
Sounds like the location you found!
Merry Christmas!
Shuboxlover
Thanks guys!
