Shuboxlover 478 #1 Posted December 20, 2011 So now that I have this running, I took it for a spin, but when I pull up on the brake lever, It essentially does nothing. I can still move the thing with the motion control lever no matter what position the brake lever is in. I disassembled the belt cover and top cover and inspected. I don't really see a problem unless it has the wrong size belt on it. The markings on the belt are a NAPA B81 50 Is this the correct belt or is it too long/short? Thanks guys Share this post Link to post Share on other sites
pfrederi 17,876 #2 Posted December 20, 2011 Belt should be a WH 7478 Gates converts that to a 6984. Taht is an 84 inch belt. Your numbers look more like a an 81 inch belt. Share this post Link to post Share on other sites
Shuboxlover 478 #3 Posted December 22, 2011 Ideas Anyone??????? Share this post Link to post Share on other sites
pfrederi 17,876 #4 Posted December 22, 2011 Does the belt feel loose when you pull up the lever...if not see my first reply. Share this post Link to post Share on other sites
Shuboxlover 478 #5 Posted December 22, 2011 I called NAPA.....84" long... Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #6 Posted December 23, 2011 Is the current belt rubber or fabric coated? Are the tabs and/or wire guides (if applicable) in place and adjusted properly at the engine pulley? Share this post Link to post Share on other sites
BOWTIE 226 #7 Posted December 23, 2011 A B81 BELT IS 84" AND SHOULD BE CORRECT. THE A AND B SERIES BELTS MEASUREMENT ARE DIFFERENT (A) SERIES YOU ADD 2 INCHES TO PART NUMBER AND ( SERIES YOU 3 INCHES TO PART NUMBER. GOOD LUCK BOWTIE IN OHO Share this post Link to post Share on other sites
corn53 4 #8 Posted January 3, 2012 Im having the same exact problem with my 73 14 auto. Put in new belt and now it seems 2 tight. Its also a 84 inch belt and compared it to the old one and it seems compatible. Did u figure it out yet? Thanx Share this post Link to post Share on other sites
