Jake Kuhn
Got a 73 John Deere 140 Tonight
Jake Kuhn
Well my grandparents had a 73 140 they wanted me to have and went and got it tonight.She had all the paper work to it and she has completely bored the engine and bought a new hydrauilic clutch for $300 :omg: .It looks to be in good shape besides the hood and some white paint on the left fender.Lucky for me I have a nice hood and grill sitting upstairs. It had been sitting for 2 years without running and she never touched the battery,I got there and it started right up.It also came with a really heavy duty John Deere dump cart.I will try to get some better pictures tomorrow when it is light out,Jake
post-4240-0-95750400-1324260076_thumb.jp
post-4240-0-40612100-1324260139_thumb.jp
Kelly
Those are very nice tractors, looks to be a H1 machine with single hyd. the H3s are very sought after tractors, is the dump cart a model 80? those are also nice heavy carts
Jake Kuhn
I'm not sure on the cart because it was dark out,but it is really heavy.Was only 10 miles from you,thought about coming but was already dark,Jake
Kelly
Wish I would have know you could have stopped in, I have lights. Nice score anyway.
Ken B
Nice score on the 140. That is one garden tractor that I have yet to own. The carts are at times as collectible if not more so than the tractors! If it is a model 80 cart then you really scored!
AMC RULES
Looks like a new restoration project? :eusa-think:
Jake Kuhn
I wouldn't want to restore something this complex.The cart is indeed a 80,What are these vaued at?Here are some pictures of it from tonight,Jake
post-4240-0-67756300-1324339810_thumb.jp
post-4240-0-10437500-1324339849_thumb.jp
post-4240-0-91409300-1324339908_thumb.jp
post-4240-0-04377600-1324339971_thumb.jp
post-4240-0-48469700-1324340048_thumb.jp
post-4240-0-48551700-1324340100_thumb.jp
post-4240-0-24278700-1324340161_thumb.jp
Ken B
On the cart, it all depends on whether or not there is a desperate Deere guy needing one to put the finishing touch or the cherry on top of a recent restoration. I do know of a few that sold in the 250-400.00 range. Condition is everything.
You could make that 140 look real nice in a jiffy. No need to go crazy on a full blown resto if the mechanics of the tractor are good. The hood looks to be decent, time saved there. Spend some time cleaning and prepping, then bust out a six pack of Rustoleum John Deere green paint, maybe two cans of yellow and you'd have a sweet 140 there in no time.
fireman
That's the next tractor on my list to find although I want an 140 H3 :notworthy:
CasualObserver
I saw you mentioned white paint. Are you sure it is a 73? If you're not sure, I'd check more into that white paint. Is the green on top of the white, or white on top of the green? I see you have a few other square fender John Deere's in your list, so you know about patio tractors, right?
Any way you look at it though... it's a nice tractor and cart to have.
Jake Kuhn
Thanks for all the replies.Jason,I do know about the patio tractors,The white paint looks like it was just some interior paint that was spilled.I took a piece of scotch brite and sanded it and it is green underneath.It has the original manual and it is a 73,Jake
Racer5x
Very nice!
T-Mo
Jake,
As you are aware, the place to check on value of the 80 cart is wfm. Be aware they do not allow "What's it Worth" questions, but you can do a search and there should be 80 carts listed in the classified sections there.
BTW, I also have a 140H1, a 1970. It needs an engine, but I have a line on one from a JD 312 that should bolt right in. The 140s are excellent tractors, and as mentioned, especially the H3s.
mowerman1193
Something is not right with the tractor if it is in fact a 73. There should be turning brakes on the right side of the tractor and no clutch peddle on the left..I have two 140 H3's a 1973 and a early 1968. The 1968 and I believe early 1969's have rear disc brakes and the later models have drum style brakes with two peddles ( one for each rear wheel ) on the right side of the tractor ( sitting on the tractor ). Your tractor appears to be a early model as you only have the clutch disconnect peddle on the left side.
Either way you got a nice tractor+ cart...Those carts bring 250+
Kevin
Jake Kuhn
Kevin,It is only a h1 and the manual has pictures of it the way it is so it should be correct,Jake
shallowwatersailor
Nice tractor! Definitely one of the more desirable JDs!
T-Mo
Kevin
The H1s only had turning brakes on a couple of years. I have a 1970 H1 which has turning brakes, but the later ones, from about '71 or '72 up didn't have them. A 1973 H1 didn't have turning brakes. But a '73 will have the improved transmissions.
