John Sullivan
snow plow
John Sullivan
Hi all
I have a 520-8 speed tractor. I am looking to install plow ser# 220000491 mod# 79362. Question is this plow compatible with my tractor.
Thank you
John
TT
79362 would be a 42" single-stage snowthrower. :scratchead:
John Sullivan
Hi
Sorry model number should have been #79364
Thanks again John
Kelly
That is a 2002 48" plow, it will fit, BUT, you will need the extenstion kit made for the 520's to clear the forward swept axle, the kit cost more than nice plows, but members here have made their own kits, do a search for 520 plows.
Kelly
Here is a thread with pics
John Sullivan
Thanks Kelly
John
  • Similar Content
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • captjack
      By captjack
      Ahoy!  captjack.  I went to Manhattan, Kansas and purchased three Wheel Horses.  Along with the machines were a snow plow and the required items to attach it to a WH.  I also have a set of concrete wheel weights.  The plow appears to be very slightly used. As I am a John Deere AMT collector, I have no idea what a fair price would be.  Could someone let me know and, also, I can deliver them.
      Thanks and stay safe.
      captjack
    • WVHillbilly520H
      By WVHillbilly520H
      @WHX24, @PeacemakerJack, @ebinmaine, @JCM, @shallowwatersailor, @pullstart, @Horse Newbie, @elcamino/wheelhorse, @Ed Kennell, and the rest of RS ....
      As I have mentioned before I would be getting snow removal tools for my Mahindra eMax 22, the whole package plow, blower and soft cab, I had purchased a Kubota set-up a couple years back with the intentions of modifying it to fit/work with it but after careful consideration decided just to sell it to help pay for the correct set-up built for Mahindra (by Berco in Canada), I ordered it the end of October and its showed at the dealer in PA right before Christmas and I just picked it up Friday, and today got the sub-frame (which both the plow and blower use so you can switch between with ease) assembled and mounting brackets installed on the tractor frame (the only thing I don't like is you have to switch these brackets back and forth between this and the mower deck mounts "not quite WH easy" but after a few times it may not be so bad ), then installed the sub-frame , snow plow and ran the hydraulic lines and plugged into the loader/sector valve. The cab and blower assembly will follow within the next few days/weeks. Pics and a little video of it in operation.
      20210110_163214.mp4
    • Bushradical
      By Bushradical
      Howdy everybody! I've got a Wheel Horse 310-8 set up for plowing snow. Wheel weights, chains etc. Ive been plowing with it all winter ...but I don't know if I'm doing it right. I usually run it in third gear "HI range" and just Give er'!  Is it better to use 2nd gear?  I don't have anyone to ask about the right way to run a plow tractor, so any advise would be appreciated.  I don't want to break anything if i can help it.
      Thanks , Dave W
