Shuboxlover
753 Transaxle Oil
Shuboxlover
I'm gonna change the fluid in my 753's tranny since I'm picking up the 3 seals today, what kind of fluid should I use?
I'm also changing the fluid in my GT-1642 which calls for sae140. Is there a fluid that is the same I can use for both? I sense the sae140 won't work for the 753, but maybe I'm wrong. Could I use sae 90 in both?
Indy w h
I use 80-90 in all my round hoods Never had a bit of problem
Indy
Shuboxlover
Could I use that in the GT-1642 also???
rmaynard
Have you tried looking here? This is the Wheel Horse lubrication chart. It's found in the section titled "Wheel Horse Links".
http://www.wolverine...lubrication.pdf
pfrederi
Don't over think this transmission lube issue. WH changed its mind over the years, and as long as you keep the water out I don't see that it makes a difference in normal use. My L107 has run 40w motor oil (what WH specified back then) in the rear end for its entire life with absolutely no problems. Shifts nice even in the winter.
Coadster32
40w is specified, but I use 80w-90 in mine w/o problems. (Doesn't leak out as fast) :hide:
