SousaKerry 502 #1 Posted December 4, 2011 Got a slight engine upgrade planned for this old tired C-81 I think it will fit.... maybe need to raise the hood and lengthen the frame just a bit 2 Share this post Link to post Share on other sites
SousaKerry 502 #2 Posted December 4, 2011 oh and it's only a 22 HP upgrade Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #3 Posted December 4, 2011 oh and it's only a 22 HP upgrade A Wisconsin VF4D is only rated @ 25hp - at 2400 RPM. I seriously doubt you'll need any weight on the front end with a ±300lb engine! Share this post Link to post Share on other sites
clyde 5 #4 Posted December 4, 2011 thats a vh4d isnt it? Share this post Link to post Share on other sites
CRE1992 135 #5 Posted December 4, 2011 Do it... Simply awesome. I saw a cub that someone stuffed a 4 cylinder Wisconsin into and changed the fenders out and put truck tires on the rear with a snowplow. It was a beast. Can wait to see it. 1 Share this post Link to post Share on other sites
SousaKerry 502 #6 Posted December 4, 2011 funny thing about the HP rating one source says 25 another says 30 so I'm going with the nice round number of 30. and I believe the 300+ pounds even the heads and carb are cast iron Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #7 Posted December 4, 2011 http://www.wisconsinmotorscanada.ca/zvevfvh.html Share this post Link to post Share on other sites
jay in nc 210 #8 Posted December 7, 2011 do it ! mayby it will light a fire under my butt to do it to my 520. but that is waaaay down the list of projects. Share this post Link to post Share on other sites
Zeek 2,286 #9 Posted December 7, 2011 Nice :music-rockout: Share this post Link to post Share on other sites
VinsRJ 723 #10 Posted December 7, 2011 Now thats a way to fill an engine compartment..... I'm sure you'll have enough power to do just about anything with that WH! Share this post Link to post Share on other sites
HorseDrawn 1 #11 Posted December 10, 2011 Is it finished yet? :ychain: Share this post Link to post Share on other sites
SousaKerry 502 #12 Posted December 11, 2011 Well I pulled off the heads today bores on the engine look factory fresh, pretty good for an engine manufactured in 1952 and sat in stored for the last 20 years, And I only broke off 3 head bolts, hard to believe the bolts were of the shelf grade 5, 5/16-18 should be easy enough to drill out. Had to completely disassemble and sand blast the carburetor, rebuild kit is on order..... I may actually try to start it by the new year. That is if Santa is nice and brings me a gasket set. Ben thinking about where to add the 6" to the frame, if I add it to the front it would give it an over hung look like a bigger tractor but I worry about putting that much weight over the front wheels. Whatcha guys think? Share this post Link to post Share on other sites
smoreau 658 #13 Posted December 11, 2011 Well I would add in front of the axle if you plan on using factory attachments, But if you don't plan on that I think it would look better if you added it to the center of the frame. Just my thought. Share this post Link to post Share on other sites
CRAZY4WHEELHORSES 0 #14 Posted December 13, 2011 YEAAAH BUDDY! Cant wait to see that in motion! :bow-blue: Share this post Link to post Share on other sites
6wheeler 660 #15 Posted December 13, 2011 That will be neat to see when its done. Last spring I put 100 pounds of front end weights on the C- 120 for plowing the garden. All I got done was, back it out of the garage. When the front end dropped off the floor on to the apron (app. 3/4"drop) , the left front spindle snapped. I repaired the spindle and dropped the amount of weight to 50lbs, and it held. Just food for thought. Pat Share this post Link to post Share on other sites
Rooster 191 #16 Posted December 27, 2011 There are some "re-powered" tractors.. There are some "overpowered" tractors... Then there is .... Awesome Project! Share this post Link to post Share on other sites
Calebintn 1 #17 Posted December 27, 2011 Looking good keep it up :woohoo: Share this post Link to post Share on other sites
CRE1992 135 #18 Posted January 22, 2012 Any updates?? Share this post Link to post Share on other sites
SousaKerry 502 #19 Posted February 27, 2012 Well I got the engine started this weekend took a total teardown and new rings, carb kit and lots of elbow grease, but the beast lives 1 Share this post Link to post Share on other sites
WH Raider10 17 #20 Posted February 27, 2012 Wow, that's awesome! I like that engine! :bow-blue: Share this post Link to post Share on other sites
farmer 1,075 #21 Posted February 27, 2012 Suddenly that frame looks very small, amazing what some of you chap's dream up, good luck with it, (hope you've started working out). :handgestures-thumbup: Share this post Link to post Share on other sites
COMMANDO1 23 #22 Posted February 27, 2012 WOW ROCKS THE WHOLE TRACTOR....SWEEEET. Share this post Link to post Share on other sites
SousaKerry 502 #23 Posted February 28, 2012 That frame is stretched 6in already now its gotta get wider so i can mount the engine properly. WHEEL HORSE STYLE!!!!!!!!!!! Share this post Link to post Share on other sites
smoreau 658 #24 Posted February 28, 2012 You going to have stacks coming out of the hood!! That would be :wicked: Share this post Link to post Share on other sites
bowtiebutler956 650 #25 Posted February 28, 2012 Some times to much is just barely enough! Thats wicked! :thumbs: Share this post Link to post Share on other sites
