AMC RULES 37,141 #1 Posted November 26, 2011 Made the time to finish installing one of Doc in Kentucky's hydro foot control kits on my first year 520-H today. Turned out great, I do really like it, but I think I'm going to adjust the reverse out of the foot control as it only seems to operate at half speed anyway. I want my pedal to control forward speed and back to neutral only, more intuitive that way I think. The kit installs without over riding the factory controls, so I'm fine with keeping my reverse function as factory, on the stick. I won't bore you with all the minute details, rest assured the supplied instructions are spot on. Just a quick pictorial overview of the process. Directions start by removing the lower control cover plate to access the motion control pivot bracket, additionally both left and right side covers will come off at this time also. You are basically just adding another (red) control bar onto the factory motion control pivot bracket. You then add the new control rod to the bottom of that and run it under the dash panel. The other end of the rod then extends out of the right side cover when you will attach the pedal assembly later on. At this time you will modify your right side cover by cutting a 3/4" slot for the foot control pivot. You now proceed to mount the pedal assembly to the right side footrest, I used the supplied backing plate that gets mounted to the bottom of the footrest as a template to mark and drill out the holes. Lastly, the pedal assembly is mounted to the footrest, and it's pivot shaft is connected to the control rod via a supplied trunnion, as seen here. All in all, it's a very easy install. I spent a couple of hours earlier this week and a couple of hours this afternoon. Honestly, I probably spent more time putzing around than I did installing the kit. DOC for making this kit available to the Wheelhorse Community! :wh: 4 Share this post Link to post Share on other sites
can whlvr 993 #2 Posted November 27, 2011 looks very nice,i would really like to get one of those some day,i had a green machine that was foot controlled and i really liked it Share this post Link to post Share on other sites
dgoyette 12 #3 Posted November 27, 2011 Looks great, thanks for all the great photos. I like the idea of the pedal for forward and reverse on the stick. It makes a lot of sense to me since there is no return to neutral on the pedal design. Share this post Link to post Share on other sites
AMC RULES 37,141 #4 Posted November 27, 2011 That's not necessarily true though, when leaving the factory controls in place. When you apply reverse direction to the foot control, the stick still falls back into it's neutral detent. :wh: Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #5 Posted November 27, 2011 Depressing the brake pedal still returns the DCL to the neutral position too. Share this post Link to post Share on other sites
dgoyette 12 #6 Posted November 27, 2011 That's not necessarily true though, when leaving the factory controls in place. When you apply reverse direction to the foot control, the stick still falls back into it's neutral detent. So the pedal will return to neutral if you take your foot off? TT - yes I did know the brake works still. Share this post Link to post Share on other sites
AMC RULES 37,141 #7 Posted November 27, 2011 No, at least mine doesn't. I said that by leaving your factory controls hooked up, when your apply reverse direction to the pedal, the stick also goes back, and falls into it's neutral detent. It should be easy enough to accomplish by simply hooking a spring up to the pedal assembly. Not sure why it's necessary though, unless you have a safety issue in mind that I'm not considering? :dunno: Share this post Link to post Share on other sites
dgoyette 12 #8 Posted November 27, 2011 No, at least mine doesn't. I said that by leaving your factory controls hooked up, when your apply reverse direction to the pedal, the stick also goes back, and falls into it's neutral detent. It should be easy enough to accomplish by simply hooking a spring up to the pedal assembly. Not sure why it's necessary though, unless you have a safety issue in mind that I'm not considering? Didn't say it was necessary, but it is very nice. I have used hydros with return to neutral and foot control and it is really slick. But I think the point is as I first stated it does not have it. Share this post Link to post Share on other sites
Tankman 3,520 #9 Posted August 1, 2012 Looks great. I have a pedal similar on my other "thing" (Cub Cadet). Used skateboard grip tape on my '73 footrests, looks and feels fine. Had I been in the steel biz (still), would use aluminum diamond plate. Perhaps later. 2 Share this post Link to post Share on other sites
imtheo 0 #10 Posted August 12, 2016 Guys, I have one of these on my 1993 520H and I am hoping to find one to put on my 1995 520H. We love how it works and the lady of the house won't drive my 1995 until I get one. UGH... Any ideas on where I can find one? If they aren't anymore, I suppose I can find a machinist to build me one of mine, but I hate thinking of taking my '93 apart to use as a proto. Any thoughts? klec@mchsi.com is my email if you do. THANKS!! Share this post Link to post Share on other sites
wrightorchid 261 #11 Posted August 12, 2016 look up Matt's Custom Hydro Pedal Kit in the Vendor section. He has a similar setup. 2 Share this post Link to post Share on other sites
Huntingtown520hc 6 #12 Posted December 28, 2020 Getting ready to install a 8-3900 foot pedal on a 1989 520hc. Has anyone installed one and if so do they know if I will need to remove the floor mounted direction control lever? Share this post Link to post Share on other sites
AMC RULES 37,141 #13 Posted December 28, 2020 Made the choice... to leave mine in place. 👍👍 1 Share this post Link to post Share on other sites
Huntingtown520hc 6 #14 Posted December 28, 2020 Fantastic thanks , any tips or lessons learned ? Did you leave the return to neutral spring hooked up? Share this post Link to post Share on other sites
AMC RULES 37,141 #15 Posted December 28, 2020 (edited) Nothing difficult... pretty straight forward following the supplied factory directions. All the factory hardware is still in place on my 520. Edited December 28, 2020 by AMC RULES Share this post Link to post Share on other sites
Huntingtown520hc 6 #16 Posted December 28, 2020 Thanks Craig, I like those front tires as well. 1 Share this post Link to post Share on other sites
Huntingtown520hc 6 #17 Posted January 7, 2021 Do you still have a copy of your installation instructions? The copy post on the site are pretty unreadable. Share this post Link to post Share on other sites
Huntingtown520hc 6 #23 Posted January 8, 2021 Thanks this a huge help! Share this post Link to post Share on other sites
Handy Don 12,662 #24 Posted January 8, 2021 (edited) On 12/27/2020 at 7:56 PM, Huntingtown520hc said: Getting ready to install a 8-3900 foot pedal on a 1989 520hc. Has anyone installed one and if so do they know if I will need to remove the floor mounted direction control lever? The floor-mounted motion control lever attaches to the motion control pivot bracket by a single bolt. However, there isn't enough clearance to get the bolt in or out while the bracket is in the tractor (a cross-frame brace just forward of the bracket is too close). Your "keep or remove" decision point comes just after Fig. 3 in the instructions, before you replace the pivot pin. Another point not mentioned is that if you remove the lever, you must also find a solution for the neutral safety switch which the motion control lever normally closes to permit the tractor to start! The kit doesn't provide for that. Edited January 8, 2021 by Handy Don 1 Share this post Link to post Share on other sites
Pops 18 #25 Posted January 8, 2021 I have Matt’s setup on my 520h, the problem I have it’s fine in forward, but in reverse it barely moves. When it is in neutral it creeps in reverse. I would think if it creeps it would move forward due to the speed variance. The tractor worked as it should before the change to the foot control. I am missing something in adjusting. thanks Share this post Link to post Share on other sites
