carlsbarn2
pulley size
carlsbarn2
My C-175-8 needs to slow down a little.Its a 1983-84 Black hood so what pulley do I need ? My 1987 310-8 speed is just right.
Kelly
They should have the same size pulleys, the engine drive pulley should be a 4" the trans is a 6" or there abouts, do they both have the same size rear tires? a taller tire will make it faster.
carlsbarn2
Tires are same size but 1 is turf,other ag.
Kelly
Just because the numbers on the tire are the same does not meen they are the same, best way to check is wrap a tape measure around the middle of the tire, the bigger tire will be faster, also is the engine speed the same?
carlsbarn2
I have no way to check engine speed but I will check tires Thank you
Rooster
Most small engine shops have tachs, they should not charge you much if at all to tell you what it is running.
