TT-(Moderator) 1,162 #1 Posted June 23, 2008 **Split from the original post HERE. And by the way, all I figured out about that resistor was it is a 2200 Ohm with a 10% tolerance.... Any help? Kevin How 'bout this, Kevin? A direct excerpt from the Kohler TP-2379 manual states: In some applications a 22 ohm, 1/2 watt resistor has been placed between the key switch and the ignition coil. This has been added to prevent current feedback through a dirty or wet switch. This feedback, if not held in check by a resistor, can damage the trigger unit. Share this post Link to post Share on other sites
kpinnc 14,871 #2 Posted June 23, 2008 Imagine that! Makes sense! Guess it's time for a trip to Radio Shack! Kevin Share this post Link to post Share on other sites
