bwebb111076
Manual P.T.O. (B-60)
bwebb111076
I am in the middle of rebuilding the manual pto on my B-60. When I took it apart, the spring was broken. I looked up the spring (PN-105031 for the B-60) and it is discontinued. But the C-160 spring is still available (PN-104841 for the C-160, C-120, and B-100). Can I use the 104841 spring on the B-60 pto.
rmaynard
There shouldn't be a problem. The stud in the end of the crankshaft should be 7/16", and that is the same as the C-160. Everything else is the same.
