stevebo
417-8 With Swept Forward Axle Conversion & 3 PT
stevebo
This is NOT a show tractor rather my worker. I purchased a complete swept forward gear reduction front end from Matt860 off a 520. I was able to get it installed with a few minor mods including having to shave about 2 inches off the horizontal length of the rock shaft and added a a pillow block on the dash tower. Again... this is not a show machine but it really does steer smooth with one finger :thumbs2:
smoreau
Very nice worker there Stevebo. I take that it is a 86 as it has lights on the dash. I have a 85 417-A for a worker and love the power of the kohler 17 series II engine! How does the rear lift work on your tractor? I don't see a lift handle and its a 8 speed, :thumbs2: how you make the 3 pt work up and down.
Coadster32
Looks good from here. :thumbs2:
VinsRJ
Looks good to me too...... :thumbs2:
stevebo
Scott,
The 3 point mechanically works the same. Only difference is that the rockshaft moves by the linear actuator vs hydro.
wallfish
My 416 will be getting this upgrade soon.
Just curious, why did you need to do this?
stevebo
John,
It is overkill I know however the 300/400 and 500 series are known to have a very poor design on the steering. Every one that I have ever owned get loose and the bushing on the inside of the dash tower ends up with a lot of play. I added this, reinstalled the bushing with a new 3/4 collar to hold it in place and added a 3rd bushing just below the original bushing (but did not bolt it in) just in case... I can tell you this set up has ZERO play :thumbs2:
Coadster32
Should last a lifetime as well. :thumbs2:
mattd860
Looks good Steve!!! Nice Job.
dgoyette
Stevbo that is a great worker you have. Great set up!!!!!
smoreau
Scott,
Is that a factory liner actuator? or a aftermarket one? and how well does it lift the with a load? I am getting ready to do a 3 point on a 91 520H soon, and looking for ideas :thumbs2:
stevebo
Factory electric. Your 520 hydro is strong enough to lift any cat. "0" implement.
smoreau
Thanks Stevebo! n1defan is also building one for his c120 8 speed, and that's why I was interested in the electric lift. I am planning to use my original hydro lift on my 520H. :thumbs2:
