mickrochip 3 #1 Posted October 10, 2011 hello there , I am new to this forum,and i was wondering if any body ca help me, how do you drain the gear box of my tractor,and what type of oil does it use, it is a c-141 8 speed thanks in anticipion for now Share this post Link to post Share on other sites
farmer 1,078 #2 Posted October 10, 2011 Hello Microchip, its THE site for You will find the drain plug just left of centre on the underside of the rear axle, it has a hex socket so you'll need a allen key. Cleaning out the socket with a small pick first is a good idea. If you can drop the oil when its warm..after a mow maybe so much the better. 90w gear oil is the grade you need. :thumbs2: Share this post Link to post Share on other sites
mickrochip 3 #3 Posted October 12, 2011 thank you for the info. will get the oil out tomorrow Share this post Link to post Share on other sites
mickrochip 3 #4 Posted November 2, 2011 Can any one please tell me how to get the "mayonaise", oil filled with water, out of my gearbox, is there something thati can use to flush the gearbox , or will it have to come apart to clear out th box Share this post Link to post Share on other sites
meadowfield 2,650 #5 Posted November 3, 2011 it might be worth splitting to inspect... Do the seals leak? if so you can do it all in one go. When you have done get the new shifter boot #3577 - I know that part by memory !!! If you feel really lazy, you could buy a gallon of cheap tesco motor oil and run it with that, and then drain - it might pull out more of the dross! mark Share this post Link to post Share on other sites
Martin 2,133 #6 Posted November 3, 2011 ive had great success with flushing with diesel. fill it right to the top of the trans and spin the insides a few times by hand with different gears selected, then drain. you will find if any seals leak at the same time. ive had one that i needed to repeat a few times, but it came clean eventually and now the oil is clean. you might want to flush with oil a few times after the diesel. bit of work to do this but if you have a good working trans that doesnt leak everywhere, its alot easier than pulling the trans and splitting the case. and replace that boot if you havent done already, odds are thats what caused your situation to begin with. Share this post Link to post Share on other sites
mickrochip 3 #7 Posted November 3, 2011 thanks for all your information, I will carry out these tasks tomorrow, will let you know how i get on. I have 1 more problem, the angle bracket that the pto clutch lever sit on has an elongated hole and therefore when i try to cut grass the mower ends up stalling, it is all right when i hold the lever up in its right position. how can it be fixed quickly and easily Share this post Link to post Share on other sites
meadowfield 2,650 #8 Posted November 3, 2011 easiest fix is to replace... let us know the part number - and show a picture, it's amazing how friendly and helpful we can all be! mark Share this post Link to post Share on other sites
mickrochip 3 #9 Posted November 12, 2011 sorry to have taken so long to reply, the partpart no of the part that i need is 104729 it is shown on partstree.com as engine bracket , no. 25. the hole where the pivot bolt is well worn on the bracket, and is letting the plate that operates the clutch fall about . it is possible to take the that plate off the bracket without spanners, any help will be greatly appreciated thanks for now PS. STILL NOT GOT THE GEARBOX FLUSHED Share this post Link to post Share on other sites
fordsonmajortom 1 #10 Posted November 12, 2011 Hi I had a look at mine tonight and there should be a flanged spacer No 18 in the hole in the bracket No 25 and the bolt tightened up tight.The clutch actuator pivots on the spacer. All mine are a bit floppy but still work ok. Michael Share this post Link to post Share on other sites
mickrochip 3 #11 Posted November 13, 2011 thanks for the info . the bole that the spacer sits in is worn out of shape, big enough for the flanged nut to pull through the bracket. I was going to weld the hole up an rebore to suit the spacer, or else bore the out the hole to abigger size and use another spacer and a larger washer. do you think that this is possible all comments will be greatly appreciated thanks for now Share this post Link to post Share on other sites
mickrochip 3 #12 Posted January 1, 2012 A very happy and prosperous new year to All thanks to all who replied/and or read my posts / but now i have repaired , carried out the maintainence as per your posts . Inow have a great going tractor. theonly thing is that in Northern Ireland there dosent seem to be that many wheelhorse owners or a great supply of implements for thes tractors Can anyone please help me to get pictures up loaded to the site as i would lik everyb body to see my totally oigional little tractor again thanks for now Iwill be back to the forum if there is any thing that arises with my c-141 Share this post Link to post Share on other sites
farmer 1,078 #13 Posted January 1, 2012 Hi, and Happy New Year to you, good to hear your tractor's sorted, implements can be a bit short on the ground, but you can get lucky. For help posting pictures; Go to the General Talk section......then Finding your way around RedSquare....then Posting pictures using Photobucket, good luck. :) Share this post Link to post Share on other sites
Sparky-(Admin) 22,036 #14 Posted January 1, 2012 You do not need to use Photobucket if you dont want to. With this new forum we can just copy and paste the pics right off our computers. In the bottom right corner of the box you type your post in is "more reply options". Click that and its gives you a way to add pics to the post your making. Mike.......... Share this post Link to post Share on other sites
