Lane Ranger
Sickle Bar Mower Rivets
Lane Ranger
I have a 42 inch Sickle Bar Mower (SMS-425) tht I need to replace three broken knives on . I have some new replacement knives but need to find a rivet to fit the knife blade.
The original rivet was part #1071 (thanks to Tom Flynn for the info).
Partstree says it is no longer available. I went to the local TSC today and they have no rivets small enough to go in the knife hole. Suppose to be a flat rivet, steel and about an 8th to 3/16th round and maybe no more than a half to 3/8 long.
Here is the knife blade in the sickle bar mower and you can just about see the rivets:
Here are three new blades and I just noticed one of the blades has larger rivet holes and I think I have a few more like this one:
Any guidance on a replacement rivet would be appreciated!
:thumbs2:
mavfreak
just a guess but can you cut the new rivet down to the right length or does tsc not have the right diameter
TT
Round head rivet ~ 3/16" diameter X 1/2" long. (I have a few spares for my SMS mower)
Grainger has them - if you don't mind a package of 165. :thumbs2:
Gene_S
Grainger has them - if you don't mind a package of 165. :banghead:
Good info TT!!!
Lane if you buy Graingers I'd be interested in buying a few of them... :thumbs2:
TT
Had to do it :thumbs2: :
mavfreak
TT i could be mistaken but thats a dime and thats 2 rivets
Gene_S
TT done his math... But I was hoping Lane would do three for a dime...
TT
Yep -- about 10
buckrancher
Actually the rivet is a 7/32" dia x 1/2" (.218 x .500) NOT 3/16" sorry TT
and good luck finding them
Brian
I found a source for 7/32" x 1/2"
looks like $6.00 per 100pcs I'll get the web site info and post it
http://www.rivetsinstock.com/rivet67.htm
mavfreak
where would a rivet fit on a moose?
I'm going to look at work tommorrow and see if the rivet size that holds the ring gear on the drive hub of a toro spartan/reelmaster are the same size. They look close. If they are you could odear them from toro or aftermarket
TT
sorry TT
No need to apologize..... :thumbs2:
I measured the spare rivets that came with my SMS-425 & although it's not used often, they've been holding the knives tight on my mower for years. :banghead:
Edit: I found several sources for the 7/32" rivets and will check them out in the very near future. :banghead:
71_Bronco
If someone is really in a bind and cannot get these rivets, I might be able to machine a few up.
Not to long ago, my dad was rebuilding the window assembly for his '64 Falcon. One of the little aluminum rivets dropped off the bench and into the black-hole, and we couldn't find it. I had to machine up a new one at work, cause he didn't have time to wait for a pair of special order rivets to come in.
Soooo.... if someone is in dire need, I might be able to make a few if people absolutely need them. Of course, I would need a dimensioned print of the parts though.
Although, from the sound of it, it looks like the rivets are available.
Lane Ranger
Thanks TT , Gene, Brian, Heath and 71 Bronco!
For All the good information on these little rivets!
I appreciate it.
Gene: Whatever I get I can send you some !
:thumbs2:
mavfreak
I looked up R&R Products for the rivets I metioned above and there 5/16 x3/4. Sorry
VinsRJ
I actually found it easier to just weld new tips to the knives... shape and sharpen. Unless you plan on using it a lot...... :thumbs2: Haven't had an issue with mine.
TT
I received one response so far........
From David Nanna:
7/32 X 1/2 RD HD STEEL RIVETS IN STOCK AT $6.25 PER HUNDRED. $25.00 ORDER MINIMUM.
Jay-Cee Sales and Rivet
32861 Chesley Dr.
Farmington, Mi 48336
800-521-6777 EXT 20
248-478-6416 (fax)
E-mail: david@rivetsinstock.com
Web site: http://www.rivetsinstock.com
Anyone want to corner the market on :banghead: sickle mower rivets? :thumbs2:
buckrancher
From David Nanna:
32861 Chesley Dr.
800-521-6777 EXT 20
248-478-6416 (fax)
Anyone want to corner the market on :thumbs: sickle mower rivets? :D
TT thats the same place I found :banghead: I added the link in my first reply
:thumbs2: I wonder if I can get them in stainless? :banghead:
Brian
Lane Ranger
Thanks Brian and TT ! I appreciate the assistance with this parts search!
Looks like Jay-Cee also has 7/32 x 1/2 steel Flat Head rives also for about the same price.
:thumbs2:
tmix
Hey try going to the oldest fram machinery shop they might have them under 2" of dust in the back :dunno: T MIX worth a try?
Lane Ranger
SICKLE BAR MOWER REPLACEMENT BLADES CAN BE PURCHASED FROM
WEBB CUTTING COMPONENTS IN NEBRAAASKA.
HERE IS THE LINK TO THE PROPER BLADE  THEY ALSO SELL SERRATED BLADES IN THE SAME SIZE!
https://www.cuttingcomponents.com/jari-replacement-section-102500-2-w-x-2-13-16-h-3-16-hole-on-1-3-8-centers.html
Replacement Rivets
Yes You can still get the replacement rivets (Wheel Horse Part # 1071)  from Jay-Cee Rivets in Michigan.
The rivets are siz 7/32 x 1/2 long Round Head Steel.
https://www.rivetsonline.com/s0218r00500/s0218r00500
Edited by Lane Ranger
