tbbahner 28 #1 Posted September 27, 2011 Hey all. I'm trying to figure out what's up with my GT14 tiller. I think I have an incorrect pulley on mine. It appears to be about 1/4" wider than the other pulleys. As a result, the belt rides way down in the pulley, making the belt too long. The belt is 89"-90" long, a little over .5" wide which looks close to what it should be if I looked at the x-ref. right. Anyone out there have a tiller drive pulley on their GT14?? I'm after the measurments. I know its a keyed 3/4" bore/shaft. I'm after the outside and inside diameter of the pulley, and the width of the groove. If you can get me close, that would be great. Thought I would check around to see if I can match one up. If you have any other thoughts or suggestions, all are appreciated. Tom B Share this post Link to post Share on other sites
