jonsteffen
gear ratios for pulling
jonsteffen
i got a for speed tranny just want to know if there is a formla to take the gear ratios from the tranny i got to figure out what they would be if the tractor came from the factory with 20in tall tires and i want to run 26in tall pulling tires can anyone help :thumbs2: :banghead:
Jim_M
Do yourself a favor and forget the 4 speed, it won't last. Get an 8 speed, 8 pinion transaxle.
jonsteffen
the four speed has the 1 1/8 axles and the 8 pinion i bored everything out to run the 1 1/8 axles
:thumbs2:
Jim_M
Get an adjustable pulley for the crankshaft and a couple of different size belts. You can change your gear ratio by opening and closing the pulley.
jonsteffen
ok this may sound dum but what doesa adjustable pulley look like :dunno:
