Stigian 1,234 #1 Posted September 16, 2011 Morning Guy's, just a quick question for you. Are the Eaton axle oil seals the same as a 8 speed trans (1 1/8" axles)? Looking at the seals that are on the Eaton they have a steel outer casing, are these the original seals and any tips on getting them out? Cheers Guy's. Share this post Link to post Share on other sites
Don1977 605 #2 Posted September 16, 2011 I would think that for 1 1/8" axles they should be the same seal. Toro seal are now all vinyl and some people have had trouble with them not sealing. I used after market seal on my 8 speed a couple of years ago they had the metal case. You need something with a sharp hook to pull them out. I had to drive the hook through the metal case to pull mine out. There is a bearing chart with the seals at the top of this page on a sticky. There are some changes down in the tread on some of the bearings. Share this post Link to post Share on other sites
kpinnc 16,188 #3 Posted September 16, 2011 They are completely different Ian, The outside diameter is larger, and the seal has a metal ring to strengthen it. A regular rubber seal could pop out if the return side of the hydraulics pressurize the sump. Sorry that I don't have the part number handy for you. Kevin Share this post Link to post Share on other sites
pfrederi 19,266 #4 Posted September 17, 2011 WH part 6449 SKF/CR 11124 Share this post Link to post Share on other sites
Stigian 1,234 #5 Posted December 3, 2011 I forgot I had posted this until the other day and had a quick look. Thanks for the advice Guy's and thank you Paul for the part numbers, I managed to order some last night :banana-tux: Share this post Link to post Share on other sites
