71_Bronco
Part Number Confirmation / Question
71_Bronco
I am looking to replace the outer seals on my Hydro unit for my Bronco 14. I found the part number "6449", Axle Seal, 1 1/8" I.D.
If somebody can just double check that, it would be very helpful. This was the first time I looked up a part number, and actually had to use the model number for a 72 Bronco, as the 71 had no listings for parts break-downs.
Also, I have been reading up on how to replace these seals, and it looks pretty straight forward. Remove hubs & Keys, & pick out the old seal. I read about the tape trick to avoid cutting the seals on the key-ways, and a little grease / oil on the shaft to make it slide easier.
Anything else I'm missing? I want to replace what I can on the unit without cracking it open, as it is working fine and no issues.
Thanks
WH854
Thanks
Ditto on that P/N 6449 :thumbs2: PS put a little anti-seize on your hub when you put it back on the axle.
Chas
rmaynard
1971 & 1972 Bronco 14 have the same transaxle, and use the #6449. That number crosses over to an SKF 11124 if you want to get it from an auto parts store like NAPA.
