snookman1 1 #1 Posted September 6, 2011 i need the axle snap ring (part number 7169), is that something that is oem or can i pick that up a tmy local machine shop. also has anyone swaped seals, 100442, somewhere i saw you could use chicago rawhide seal cr6128 but they had question mark next to it like they were not for sure if it would work. help please. Share this post Link to post Share on other sites
WH854 44 #2 Posted September 6, 2011 i need the axle snap ring (part number 7169), is that something that is oem or can i pick that up a tmy local machine shop. also has anyone swaped seals, 100442, somewhere i saw you could use chicago rawhide seal cr6128 but they had question mark next to it like they were not for sure if it would work. help please. 5/8 (.625) Input Shaft 100442 C/R 6105 you can go to the top of the Transmissions and Transaxles there is a penned message at the top about bearings and seals.MikesRJ has a PDF File about them The snap ring is available from Toro P/N105876. Chas Share this post Link to post Share on other sites
racinfool40 202 #3 Posted September 6, 2011 Josh E-mail sent.. I have all you need.. Except the seal.. :banghead: Share this post Link to post Share on other sites
