Countdown To Christmas!
dgjks6
valve to tappet clearance
dgjks6
OK - I know I am a newbie and should not be doing this, but...
anyway
Tractor has 509 hrs so I followed the owners manual for the 12 hp magnum engine and it says to adjust the valv to tappet clearance
so far have completed step 1 - removed air cleaner, carb, and breather
step 2 is to position the crank shaft so the piston is at the top of the compression stoke
how do I do step 2? I can move this piston and watch the tappets go up and down - but how do I tell when it is up - and which valve am i looking at?
GReg
dgjks6
OK - I'm getting closer
intake on right below carb
exhaust on left by muffler - that was easy :whistle:
Now the adjustment I assume is the 7/16 nut I see, but if I spin it, the tappet goes with it. So how do I hold the tappett?
9/16 too small and 5/8 too big :WRS:
can I spin the tappet freely? I hope so cause I have done this a bunch
btw, I assume piston at top is when the tappett is at its lowest ponit - cause I can slide a feeler gauge in at that point, but the intake is .006 and I need to get it to .009 -
If any one can help I would love it
If not I will keep posting my progress
Greg
dgjks6
OK, so I am done
I hope I did it right
What I have found out
The tappetts spin freely
When the piston is at the top - both tappets are at their lowest position
The tappet is a 9/16 - and the adjustment nut is 7/16
you need a slim 9/16 though
The intake valve was only off by .001
The exhaust valve was off by .005
There is a lot of gas in a carb when you take it off
There is a lot of oil in the engine where I was working - now it is on the garage floor
Taking off the hood wold have sped this whole process up
I love my tractor store - he gave me all the gaskets and a green thing- the first time
So this is my story
Now to figure out how to hook up the bagger and fix the brake pedal
Then I am going to take off the head and clean the cylinder
Then I am going to rebuild the carb
then my wife is going to divorce me for "spending time fixing a tractor that already ran fine"
Greg
kj4kicks
Sounds like you got through it just fine. Did it run any better after the adjustment?
dgjks6
will let you know
still trying to get old gasket material off without using a metal scraper. Guy at toro dealer said they do not use sealer with new gaskets, so I'm trying to clean everything.
dgjks6
last update if anyone cares - she runs great
and it used to back fire when turning off which is now gone :whistle:
