timmybobwatt 0 #1 Posted September 3, 2011 Hi all. When I engage my 227-5 and operate it sounds like there is a dry 'crunching' sound from the tranny. According to the manual, these are pre-packed with grease and don't require lubricant replacing? Has anyone any ideas? The sound is present when I release the clutch pedal put not when pressed. It is constant during operation. TIA. Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #2 Posted September 3, 2011 Sounds like it could be the input shaft bearings. With the engine off & the clutch pedal depressed (so drive belt is loose) try to wiggle the large pulley on the top of the transaxle. Share this post Link to post Share on other sites
