azc145 0 #1 Posted August 26, 2011 I have a C-145 that has an oil leak on the hydraulic valve lift valve. The valve works great it just leaks. Any ideas on where I can get new O-rings? Or maybe an alternate approach that I could use to seal the leak? The only marking that I can find on this valve is "Ward Co". Any ideas on how to better identify this valve? It does not look like the two valves that are shown in the C-145 parts manual. Attached Image (Click thumbnail to expand) Share this post Link to post Share on other sites
azc145 0 #2 Posted August 26, 2011 Here's another picture of the assembled unit. Attached Image Share this post Link to post Share on other sites
azc145 0 #3 Posted August 26, 2011 Here's another picture of the assembled unit. Thanks for your help!!! Attached Image Share this post Link to post Share on other sites
SousaKerry 502 #4 Posted August 26, 2011 Any Hydraulic shop should be able to help you, let your fingers do the walking as they say.. The oval seal is just an o-ring that has been in that shape so long that it stays that way. You can do a little measurement and find o-rings at hardware and auto stores also. Share this post Link to post Share on other sites
shorts 182 #5 Posted August 26, 2011 :thumbs2: You probably go to a hydraulic shop to make sure that you get o-rings that are compatable with hydraulic oil and of the proper hardness to withstand the pressures in the system. Share this post Link to post Share on other sites
SousaKerry 502 #6 Posted August 26, 2011 as long as they are Viton instead of Buna you should be fine Share this post Link to post Share on other sites
KB9LOR 4 #7 Posted August 27, 2011 Shoot Indywh a PM, he is the resident Hyd lift guru, and I am positive he can help you out with the seals. Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #8 Posted August 27, 2011 Must be an early 1980 C-145 with a Sundstrand. (Wheel Horse p/n 106680) Check with member "kj4kicks" (Eldon) to be sure, but I think THIS KIT on his website should fit your valve. :thumbs2: Share this post Link to post Share on other sites
bigd 0 #9 Posted August 27, 2011 i bought two of those kits from milicalawn about a month ago think they were bout 6 bucks Share this post Link to post Share on other sites
