jdog_kustoms
eaton 7 or 11
jdog_kustoms
has anyone ever taken apart a eaton 11 or 7 and seen if it could be rebuilt or at least what all is inside it
buckrancher
I have a rebuid kit with o-rings and seals and a new input shaft for a #11
have not takin one apart yet does'nt look to hard just need to be clean it's
not rocket science
Brian
Brrly1
Jordan, from what I have heard #11 is rebuidable the #7 is junk but don't quote me. :thumbs2::banghead:
:banghead:
jdog_kustoms
i got a bad eaton 7 on my new zero turn i was gone take apart to see what it was like to rebuild ight have to do it some day my parts mower will keep me runnin for now
brian is the kit a wheel horse or aftermarket kit
buckrancher
I got it thru toro
Brian
kpinnc
not rocket science
True, they are very simple internally- but each of the ball pistons on both the pump and drive side of the units are matched to the port they are in. Point being, when you take it apart you MUST keep them in the correct port. The manual recommends using a large rubber band around the carrier prior to taking it apart.
If the ball pistons fall out, and you put them back in the wrong ports, you've got a paperweight.
Good luck!
jdog_kustoms
i think that is what someone else did before me so i tryied to make them fit as nice as posible but i think i have a paper weight cuase when i took it apart some balls fell out some stuck in the holes
larry Chaffin
I need parts for my zero turn mower, 616, right rear hydro, gears, casing, etc.Contact me as soon as possible. Larrychaffin55@yahoo.com
