tarcoleo
23x10.5-12 wheels and tires
tarcoleo
On my C-chassis, I would like to fit a set of 23x10.5-12 units. The center part of wheels for WH generally are deeply displaced to move the tire outward. On the
other hand, there is a JD wheel that has the center section displaced such that
the tire is moved inward. I'm wondering if that wheel would work on a WH if it were
simply reversed.
Tom in RI
tunahead72
simply reversed.
Maybe, but you'd have to shoot your Horse! :woohoo:
Seriously, Tom, I don't know the answer to your question, I think it probably depends on the specific wheel, how much it's dished, etc. I'm assuming you've checked the center diameter and bolt spacing? Is there a lip or anything else on the wheel that would prevent you from mounting it the way you want?
I do know that some of the older International farm tractors had rear wheels that could be reversed on the axles to give different tread widths, so I think on that level it's at least theoretically possible your JD wheel would work. If you're using ag-tread tires, you'll have to make sure they're rotating in the correct direction.
WheelHorseSteve
I literally just did the same thing the other day... mounted a freshly painted "Wheel Horse linen" 23x10.5-12 wheel / rim set from a John Deere on my C160. The only way it fits is with 1.5"+ wheel spacers... the offset is WAY different than Wheel Horse. It doesn't matter if you reverse it either... the JD offset is close to neutral.
On any tractor with a brake band and/or fuel tank mounted under the seat pan, you are probably out of luck even w/ the wheel spacers. The tire is literally 1/2" away from a hydro part and not far from the hydro filter either. No chains on these tires for me -- not that I had planned on using them here. Also, no chance of 24x12-12 tires either.
SousaKerry
I can tell you from experience that wheels from a simplicity will work just fine FWIW
Irv
Tom, I'm guessing that you think the 23/10.50's won't work with WH wheels. I have 10.50's on regular WH wheels on my 74 C160 (ag's) and on my 312-8 (turfs) and they fit fine.
tarcoleo
Irv-
From earlier threads I understand that the larger tire can be put on regular WH
rims with only a little ballooning. What I'm scouting for is a used pair of wheels
with the 10.5 tires--not necessarily WH--that can be used directly with a saving.
On the other hand, I'm using my pair of C chasses for grass cutting and driveway
grading only. So why do I need larger tires?
Good to learn about the Simplicity direct swap.
Tom in RI :woohoo:
SAM58
Both of these tractors have the 23 x 10.5 x 12 AG tires
the ones on the 520 look wider because the wheels are wider 8-1/2"
the 314 has the standard 7" wheel making the tire look a little narrower.
tarcoleo
In the search of 23x10.50-12 wheels and tires, it was discovered that there are
Cub Cadet units that fit Wheel Horse's perfectly. The off-set is just right and the
particular pair that I found (on ejunk) even had the valve stem on the inside of
the wheel ala WH, although virtually all other wheels from CC's that I have seen
have the stem on the outside. CC wheels in this size typically are equipped with Goodyear Soft Tracs (no longer made). The price was right at less than $75 del'd.
Hope this info will be useful to others in the same pursuit.
Tom in RI
