timmybobwatt
Desperately need a 227-5 brake pedal!
timmybobwatt
Does anyone have a brake pedal that might fit a 227-5?
Mine is in two pieces.
:woohoo:
TT
Got you covered. :woohoo: (see your PTO post)
timmybobwatt
$50 inc postage was a bit too much!
Thank you, but still after one.
<_<
wheeledhorseman
Nearly didn't spot this 'want' as it wasn't posted in the Euro section. I don't have a spare pedal but the following info may help you to track one down in the UK.
The pedal you are after was common to the 200 series tractors e.g. it's the same pedal on my 227-5 as on my 216-5. I think it may well have been common to most if not all non-automatic tractors with pressed steel chassis and vertical shaft engine regardless of engine type / size. My B series B-111 also has the same brake and clutch pedals as the 200 series.
Have you tried Bob Lewis (Horsebreaker)? He advertises stuff on the bay. Worth giving him a call (his number is on each of the items up for sale) as he has lots of bits not put up on the auction site.
