tarcoleo
The Rugged Ones
tarcoleo
About 10-pinion differentials, 1-1/8" axles, and 8- speed trans.- are the C-series
WH's the only machines with all three features?
Tom in RI :woohoo:
racinfool40
Tom alot of the raiders also had the 10 pinion tranny's. I'm still tryin to learn about all the 6-8 speed transmissions the 5060 and the 5073 in the raiders were 10 pinions 1 1/8 axle and I may be wrong but I thought the c-series came with the 8 pinion 1 1/8 axle tranny's :D
here's the one's I know that were 8 pinion tranny's
5091
103907
103916
103918
and as far as the difference in each tranny ya got me!!!
Theirs also a service bulletin some were that shows how to switch a 10 pinion tranny over to and 8 pinion tranny but I've yet been able to find it!! I hope this helps a little if not I'm sure someone with a little more knowledge than me will chime in! :woohoo:
tunahead72
Tom,
I'm curious about this also, so I hope you don't mind me asking what I think is a related question, from a complete novice on these transmissions:
Are the 10-pinion differentials necessarily more "rugged" than the 8-pinions?
Thanks for letting me cut in! :woohoo:
can whlvr
not all c series have the 10 pinipn,none of mine do and i have 4 c,s,and i dont think they are stronger than the 8 pinion,the mecanism the makes it a posi in the 10 pinion seems to wear out,and then its not posi,and dont quote me but i think the pinions are smaller in the 10 and there fore not as strong as the 8
TT
The 10 pinion "Trans-Power" differentials were only used from 1967 to sometime in 1973. (at least in the USA models)
The 8 pinion is stronger than the 10 pinion. In addition to the pinions being smaller (and hollow), the ring gear is weakened because it is "keywayed" in four places for the pinion carrier halves.
See for yourselves :woohoo: :
Wimpy, wimpy, wimpy:
Hefty, hefty, hefty :D :
Here's the comparison photo of the 8 pinion assembly vs. the early 10 pinion assembly. (aluminum end caps were used in the #5060 tranz)
Raider12
Thats a great illustration Terry. :woohoo:
tarcoleo
Terry, Mike and Don,
Good info! Now we know.
Tom in RI :woohoo:
woodchuckfarmer
Thanks Terry
